SoCal WRX FlatFour (F4) - Page 199
This is a discussion on SoCal WRX FlatFour (F4) within the South Western States forums, part of the Regional Discussion category; so hows that website coming along?...
  1. #2971
    Registered User WRX13oy's Avatar
    Jul 2003
    SOCAL!! 91752
    SOCAL F4#02 OG member
    2002 PSM WRX stage 6
    2007 Kawasaki Ninja ZX6R
  3. #2972
    Registered User volcomsoldier19's Avatar
    Mar 2005
    SoCal, Whales ******
    so the other day i was changing my oil and noticed some seepage towards the rear of my trans, i checked it out and it was trans fluid that had leaked, but from where? to me it seemed to be the shifter housing seal, the first thing that came to my mind was the issue of aftermarket downpipes being too hot and melting this seal, **** i thought, but then i remembered the 60 k powertrain warranty and took it to renick and they replaced the seal at no cost and only took 4 hours for them to do, now my next question is
    I want to wrap my downpipe, i want to do it my self is it hard to do, who has done it? who can help me?
    Quote Originally Posted by ansonowicz View Post
    So if I'm stuck in a rut or something, it's mostly because I made a wrong decision somewhere and I need to correct myself out of it.
  4. #2973
    Jul 2003
    SOCAL!! 91752
    i think paul is the expert in exhaust wrap
  6. #2974
    Registered User ansonowicz's Avatar
    Oct 2005
    LBC
    Quote Originally Posted by volcomsoldier19
    I've wrapped my downpipe and it's easy. The hard part is dealing with the stink when you wrap it. Here's what I did & I'll be glad to help out. This is what I did using Thermotec:
    WEAR RUBBER GLOVES & LONG SLEEVES!!
    1) soak the Thermotec in water, as you're handling the wrap, you'll see fiberglass filaments floating around, so don't breathe too hard.
    2) after about 10minutes, it will be very pliable & easy to work with
    3) start wrapping it as TIGHT as humanly possible with 1/4 - 1/2" overlap
    4) by the time you get to the end, use the thermotec clamps (small, thin, hose clamps) all throughout the pipe to keep it from coming apart
    5) let dry for 24 hrs. As wrap dries, it will shrink and get even tighter on the pipe
    6) re-install the pipe
    Just a note, after you install the pipe & drive around, it will smoke under the hood for about 2-3 hours. this is normal, the insulation chemicals are adjusting to the heat.
    took me about 2-3 hrs.
    F4.21 have root access, will travel
    :wq! 6MT20G
    Quote Originally Posted by volcomsoldier19 View Post
    long haul, the wagon will give you happiness in the times of madness...
  7. #2975
    Jul 2003
    SOCAL!! 91752
    i also would recomend getting the sealant spray to go with the wrap. you dont want any oil or moisture soaking through the wrap
  8. #2976
    Registered User rx4mj's Avatar
    Sep 2005
    Freezing my arse off in NYC
    I've heard of this happening to a couple people because of the exhaust temps. I used 50'x2'' to cover the whole pipe, instructions come with it and it runs about 40- 50$. I am pretty sure you are not suppose to soak it, just need to wet it briefly before you wrap that part (1 or 2 feet at a time). this will at least help it to dry in an hour or two. Let dry and I highly recomend getting the thermotec sealant like Chris2 suggested. I did mine pretty easily, but it will go faster wrapping it with two people to hold tighten and wrap. There is a store next to me that sells the wrap but not the spray, that is available through Summit racing for like 5 bucks in three different colors. I will help out also if you want. Deffinately a good mod to invest in, and helps greatly. Don't forget the gloves.
    Hey guys, I'm back!!!
  9. #2977
    Sep 2005
    After that run in GMR my front struts won't stop squeking, think it's time for some coilovers. Good news is whatever was caught making the rotational clicking noise was freed on the same run. So no drive train problems and thats good news.
    PS. Why are girlfriends so aggrevating?
  10. #2978
    Registered User PaulSaidHi's Avatar
    Mar 2004
    Cerritos
    hahah yea exhaust wrap sucks try wraping a 1 peice header.
    i heard u guys dint really drive GMR but mtbaldy road.
    Driver: Francis-Paul Dela Cruz
    04' Wrx Utec stg.3
    Home: Glendora Mt. Ridge
    F4 #09 <---- the the suby-guru in-training
    |[ D. D. i. D. ]| <--- Support the cause!
  11. #2979
    Registered User projectwrx31's Avatar
    mission viejo
    Arrow
    i'm down to host another install meet and probably we can bbq also....
    kool kool whatever i guess want to try to get alll the members there
    SO CAL FLAT 4#04
  12. #2980
    Sep 2005
    Quote Originally Posted by PaulSaidHi
    Smart as*s, haha, When you go up baldy road you make a left on GMR it just doesn't connect. Have you tried from the other way? Or made it all the way through? how is maximus doing? Damn it has been forever since I've seen you, like since the car show.
  13. #2981
    Sep 2005
    So how does poker night on friday at my house sound? $20 per person I think I can get enough chips to play with, and of course some beers.
  14. #2982
    mission viejo
    Arrow
    hmmm i'm off saturday
    SO CAL FLAT 4#04
  15. #2983
    Sep 2005
    friday or sat. What's the concensus?
  16. #2984
    Jul 2003
    SOCAL!! 91752
    im down for some texas hold'em
  17. #2985
    Sep 2005
    That is the game we are going to play, so are you in? which date is best?
