SoCal WRX FlatFour (F4) - Page 192
This is a discussion on SoCal WRX FlatFour (F4) within the South Western States forums, part of the Regional Discussion category; Originally Posted by rx4mj Uggh, not feeling to good. Haven't felt like this in a while. looks like no Morongo ...
  1. #2866
    Registered User Hytek714's Avatar
    Aug 2005
    Anaheim, California
    Quote Originally Posted by rx4mj
    Uggh, not feeling to good. Haven't felt like this in a while. looks like no Morongo for me
    alight maybe next time!!! im getting my bumper fixed tomorrow!!! only costing my $150
  3. #2867
    Registered User hellbilly1342's Avatar
    Dec 2005
    Quote Originally Posted by volcomsoldier19
    here's the breakdown i found for you noel
    The VF series (VF22, VF23, VF24, VF29, VF30, VF34, VF39) are the most common direct replacement turbos. All VF-series turbochargers use the same roller bearing, water-cooled core assembly. The differences are in their wheels and housings to achieve different flows.
    The VF22 has the largest potential for peak horsepower. In other words, in the IHI model range, the VF 22 supports the highest boost levels. It is capable of running up to 25 psi. Because it is a roller bearing turbo, turbo lag is minimal...the boost comes on around 3300 rpm. Expect to max out the VF22 somewhere in the 400-450 hp range.
    The VF23 starts the middle ground. It comes on boost around 3100 rpm and is capable of running 20 psi of boost. Expect to max out the VF23 somewhere in the 300-350 hp range.
    The VF 24 starts to come on around 2900 rpm and will significantly improve power through the midrange over the stock TD04 turbo. However, the VF 24 is only capable of running around 17 psi.
    The VF23 and VF 24 are a great replacement for those who value drivability higher than maximum power.
    The VF29 & VF30 delivers a very wide increase in torque over the standard TD-series turbos.
    The VF 30 is a fairly new IHI model that utilizes the exhaust housing of a VF24 and the compressor housing sized between a VF 23 and a VF 22. It comes on boost down low (around the 3000 rpm range). With upgraded injectors, fuel pump, and engine management, the VF 30 is good for 365-390 horsepower. It is important to note that the VF30 is NOT a roller bearing turbo.
    The IHI VF34 (which comes standard in the Japanese market STi version "RA") is a new roller bearing turbo. It has the same specifications (compressor size, etc.) as the VF 30. The difference lies in the roller bearing which, theoretically, allows quicker spool and better response. It costs a couple hundres more than a VF 30. The VF 34 maxes out around 365-390 hp. It is probably the most popular option for big turbos on the WRX.
    One other turbo to note is the VF 39...it comes standard in the USDM STi. While we don't have all the specs yet, these are a new roller bearing, TWIN SCROLL design. Performance numbers are pretty similar to the VF34...maxing out just under 400 hp
    so by this, it is most likely the VF39. I know it was the stock turbo that was from his car. I'll bring it with me to the next meet so you can check it out in person. I was trying to figure it out by checking on the IHI sight by comparing the part number on the turbo, but no luck yet.
  4. #2868
    Dec 2005
    i know why ED is laughing, Gus did this to his suby and was called a RICER.....i think it is a cool free mod, i would do an F4 one
    i agree, i may try it out this weekend along with the other stuff i'm gonna do on my car...gut the up pipe, clear the headlights, and mount the RE92's on the new rims i got.
  6. #2869
    Aug 2005
    Anaheim, California
    Quote Originally Posted by facelesskillah
    hey guys my friend sam that owns srt motor sports wants to meet up wit you all so what do you guys think??
    when is the meet up going to be?
  7. #2870
    Registered User Blofe's Avatar
    Sep 2005
    Long Beach
    anyone else up for morongo?
    So Cal F4 # 10
  8. #2871
    Registered User PaulSaidHi's Avatar
    Mar 2004
    Cerritos
    hey ed i can do the down pipe install on sat because all my tools are at a friends house i left it there after the motor swap.
    i can prob tackle the dp in and out in about 1.5 hours, pm me when u can i really need money i just got a parking ticket.
    Driver: Francis-Paul Dela Cruz
    04' Wrx Utec stg.3
    Home: Glendora Mt. Ridge
    F4 #09 <---- the the suby-guru in-training
    |[ D. D. i. D. ]| <--- Support the cause!
  9. #2872
    Mar 2004
    Cerritos
    hey btw does any one know how to do a clutch and flywheel change. i really need to change my clutch so if any one can do it for me i would be verry happy, i throw in 100$
    04' Wrx Utec stg.3
  10. #2873
    Registered User WRX13oy's Avatar
    Jul 2003
    SOCAL!! 91752
    Quote Originally Posted by hellbilly1342
    if its a vf39. you can use sti pinks and some kind of engine management. ive seen some wrx's with vf39 swaps and are putting down 270 280 hp
    SOCAL F4#02 OG member
    2002 PSM WRX stage 6
    2007 Kawasaki Ninja ZX6R
  11. #2874
    Registered User volcomsoldier19's Avatar
    Mar 2005
    SoCal, Whales ******
    Quote Originally Posted by WRX13oy
    yea a guy from the Renick dealer he doe'snt work there anymore had a 39'ed 03 and rode in it and did'nt expect much but wow it pulled hard and spanked an 04 STi it amazed me for a bare bones setup he had, he just had the 39, modded stock injectors an sti TMIC and Ecutek.....i'm going that route, but i'm getting the STi pinks for injectors
    and chris will u help me install them in about a month or so?
    Quote Originally Posted by ansonowicz View Post
    So if I'm stuck in a rut or something, it's mostly because I made a wrong decision somewhere and I need to correct myself out of it.
  12. #2875
    Jul 2003
    SOCAL!! 91752
    good choice. you can never go wrong with sti injectors untill you max them out. and i have maxed mine out already. DOH
  13. #2876
    Mar 2005
    how does one max them out?
  14. #2877
    Jul 2003
    SOCAL!! 91752
    big turbo = more air = more fuel
    ive already hit 100% injector duty cycle on some of my logs which means that im pushing them to the max. i still need just a lil more fuel. im thinking of going with some 650cc
  15. #2878
    Mar 2005
    would a 39 max them out or does it depend on the aggressiveness of the map?
  16. #2879
    Jul 2003
    SOCAL!! 91752
    i dont think a vf39 would max it out. vf34 would be close
  17. #2880
    Jul 2003
    SOCAL!! 91752
    i need your guys imput what to get for bday
