Help me out please!!
Results 1 to 10 of 10
This is a discussion on Help me out please!! within the South Eastern States forums, part of the Regional Discussion category; Okay. I have a question.. I am running a partially open downpipe. There is only a crack between my downpipe ...
    Registered User Shasty13's Avatar
    Mar 2012
    North Carolina
    Okay. I have a question.. I am running a partially open downpipe. There is only a crack between my downpipe and my exhaust. Today I was on my way home and my check engine light came on, my cruise control button was flashing, and the traction control was turned off automatically. Anyone else have problems with running open downpipe? Check engine light? Thanks guys!
            MainFrame's Avatar
    Austin, TX
    What's the code? And what tune are you running? What car?
    Mar 2012
    North Carolina
    It's a 2012 Subaru WRX hatch. Stock tune. All stock except for the exhaust. They said its my O2 sensor.
    Jan 2012
    Philly Area
    Fix the crack! Nobody likes publicly exposed crack, least of all your ECU.
    - Will
            MainFrame's Avatar
    Austin, TX
    Probably rear O2 reading lean because it's sucking air from outside the car into the exhaust past the sensor. I would imagine if you fix the crack and reset the ECU the code will go away.
    What's aftermarket about the exhaust? Just so you know, you will need a tune to safely run an aftermarket downpipe.
    Mar 2012
    North Carolina
    It's the stock downpipe. And the SPT exhaust.
    Jun 2012
    Boca Raton, FL
    Fix the exhaust leak, reset the ECU, see if it comes back. Is it P0420? That typically means poor cat performance and should not show up with the stock DP
    Palmyra, NJ
    Sounds exactly like what my car did this weekend...I have a small exhaust leak as well and got a P2096 which is what Robin (Mainframe) said.
    Registered User xFalleNx's Avatar
    Nov 2010
    Voorhees, NJ
    fix the leak
    /problem
    --Anthony 2011 DGM WRX stg2+sf intake WTFtuned ¯\_(ツ)_/¯
    Official Subie owner as of 01/10/11
    Stink Eye Mob #87
    Bye bye Bimmer
    Hellooo '11 REX
    Mar 2012
    North Carolina
    All fixed!!
