legacy 2.5 GT can I instakk a 3.0 Boxer engine in my Legacy?
Results 1 to 4 of 4
This is a discussion on legacy 2.5 GT can I instakk a 3.0 Boxer engine in my Legacy? within the Request a Tutorial/DIY forums, part of the Tutorials & DIY category; Can I install a 6 cylinder 3.0 boxer engine in a Legacy 2.5 GT?...
    Oct 2014
    Aug 2012
    Tucson, AZ
    I've seen a video of the same engine in an sti so I would assume you could as they engine layout is similar
    Hawkeye Alliance 520
    Previous cars:
    2010 Mitsubishi Lancer (sold)
    2009 WRX (sold )
    2013 Scion tC (sold)
    2008 Audi A4 (Totaled)
    Photographer/storm chaser
    https://www.facebook.com/kevinrimphoto
    IG - kevinrimcoski
    Oct 2014
    2005 Subaru Legacy 2.5 GT
    Quote Originally Posted by nsibanez View Post
    I got a code of - P1152 & P1153 it said intake runner stuck open. The other problem was Start up switch (low) Can anyone help me?
    ¯\_(ツ)_/¯ Rambo's Avatar
    Oct 2010
    Portland, OR
    Quote Originally Posted by robert f b View Post
    Is this on the 2.5L, or did you swap in EZ30?
    I would expect the swap to be quite difficult electrically, as the harnesses will not be compatible AT ALL. While both engines have AVCS, the EZ30 engine has active valve lift, in addition to timing. Mechanically, it should fit fine, as it's just an inch or two longer than the 4-cyl engines, and the engine/transmission mounts are the same, as far as I know.
    You'd want to beef up the front springs to compensate for the additional weight.
    As far as the codes you're seeing, it sounds like you have a TGV delete. What modifications does the car have?
    Oh, and welcome to the forum.
    2007 Outback 3.0R wagon
