2005 WRX AT radiator to MT radiatior DIY request
Results 1 to 8 of 8
This is a discussion on 2005 WRX AT radiator to MT radiatior DIY request within the Request a Tutorial/DIY forums, part of the Tutorials & DIY category; I've got an Automatic '05 WRX with a leaking radiator, which I gather is very common issue. I've looked into ...
    Oct 2013
    San Diego, CA
    I've got an Automatic '05 WRX with a leaking radiator, which I gather is very common issue. I've looked into some replacement radiators, and found nothing but more plastic radiators for AT. After doing research I’ve found that a nice full aluminum MT radiator can be installed, with the addition of an additional cooler (Transmission fluid radiator, if I’m not mistaken). Does anyone have a diagram for this, or any more information on this? I’d like to have an idea of the set up before I blindly start ordering parts.
    Registered User Obeisance's Avatar
    Apr 2012
    not Ann Arbor
    Contrariwise, (after an accident) I've replaced the radiatior in my 5MT WRX with that from an automatic car. Although it is also a plastic radiator, neither this one nor the stock one have leaked since I've owned the car (excepting when I crashed).
    Although the aftermarket MT radiator would be a direct drop in, the trans fluid cooler would need an additional bracket. There isn't a lot of space behind the radiator (since there are fans there) and there isn't a lot of space between the AC condenser and radiator (only an inch or so), thus the easiest spot to place a cooler may be in front of the AC condenser. I wonder if there are any commercially available brackets available.
    David - '05 WRX
    Registered User silver03's Avatar
    Jul 2003
    10000 Lakes
    I replaced our 03 wrx 4eat radiator with a mishimoto one. Yes, I had to buy an aftermarket trans cooler. I mounted it in front of the ac condenser using 2 zip ties...that was 4 years ago and to this day it's holding up terrific.
    Oct 2013
    San Diego, CA
    alright, sounds like what i've been reading. Any details you can remember about this mod that i should keep in mind when ordering stuff, or building it? I'm new to working on cars, i've been working on sport bikes for the last 10 years, so anything/everything is helpful.
    Jul 2003
    10000 Lakes
    Quote Originally Posted by Some_Biker_Guy View Post
    Not complicated at all:
    Drain radiator
    disconnect and remove fans
    remove air intake (the part that goes over the top of the radiator)
    Disconnect top and bottom rad hose
    remove overflow tank
    Disconnect tranny lines from radiator
    remove radiator
    I picked up a hayden trans cooler for about $25 from my local O'reillys I believe
    Things get messy with coolant and trans fluid dripping.
    Oct 2013
    San Diego, CA
    great info thanks
    does the set-up pretty much look like this?Click image for larger version.
    Jul 2003
    10000 Lakes
    great info thanks
    Sort of...the tranny lines will bypass the radiator altogether and go directly to the tranny cooler.
    Oct 2013
    San Diego, CA
    ok thats what i was thinking, but i wasnt sure and all the diagrams looked like this. But now i'm clear on it. Thanks a ton! I'll try to post a how-to on this once i get it done as long as my gf is willing to take pics =P
