1.) unplug the battery
2.) remove airbox and possibly washer fluid reservoir
3.) remove coil packs
4.) remove spark plugs
5.) install new spark plugs (gapped properly) using LocTite and the torque specs specified in your shop manual
6.) drink beer.
This is a discussion on ?How to change spark plug procedure for 2008 STI wagon?? within the Request a Tutorial/DIY forums, part of the Tutorials & DIY category; Can anyone provide me with a basic procedure for replacing spark plugs on a 2008 Subaru empreza wrx sti?? I ...
I know some parts will have to be removed but I need to know which ones and in what order, thank you..
6.) drink beer.
Facebook me here
Originally Posted by Mikie13
2011 STi Build LogOriginally Posted by Trainrex
So I would modify it like so:
2.) drink beer
3.) Remove air box
4.) drink beer
5.) Remove battery
6.) Remove air pump off front of engine (and pipe attached to it)
7.) drink beer
8.) remove spark plugs
9.) drink beer
10.) install new spark plugs (gapped properly) using LocTite and the torque specs specified in your shop manual
11.) drink beer.
No Mikie.
1.) Drink beer
2.) unplug the battery
3.) drink beer
4.) Remove air box
5.) drink beer
6.) Remove battery
7.) drink beer <--Damn it Mikie, taking out a battery is hard work I think we deserve a beer for the effort!
8.) Remove air pump off front of engine (and pipe attached to it)
9.) drink beer
10.) remove spark plugs
11.) drink beer
12.) install new spark plugs (gapped properly) using LocTite and the torque specs specified in your shop manual
13.) drink beer.
I said that lol.
Meh, most recently I was able to pull the plugs and do a compression test with the battery still in the car, though it might be due to the fact my Optima Yellow Top is smaller than the stock battery.
What's that?![]()
Facebook me here
Even my friends 05 STi engine bay is different from mine when the 2.0L go to do a compression test. In my engine bay it would be near impossible to get the coils out with the battery in there. My friends 05, it'd still be difficult.
You'll find the air pump... a giant plastic tube covers up most of both driver side coil packs =P
I haven't worked with a 2.0L ever, so I don't have much comparison to offer directly to yours obviously.
EDIT: Looking at pictures, it seems the battery has kinda been wedged around a bit differently over the years. Also, the obvious difference of no wiper jug over that way on the newer ones. Hopefully your 2.0L ones are easier though.
I think next time I am going to jack my engine up an inch or so. I have a bad feeling that the compression checker adapter is going to get stuck in there or something, and I won't be able to drill it out. I may just glue the adapter on as well I guess.
damnit...dunno how I missed a beer!![]()
- William
