Results 1 to 5 of 5
This is a discussion on Anyone know if I can swap out the hubs on my 02 wrx to an Sti hub? within the Request a Tutorial/DIY forums, part of the Tutorials & DIY category; I have an 02 sedan, Wrx, and im after the 5x 114 bolt pattern. What would I need in order ...
    Jan 2011
    Phoenix AZ
    I have an 02 sedan, Wrx, and im after the 5x 114 bolt pattern. What would I need in order to swap from my current 5x100? Is it as simple as hubs, or do I need much more?
    Texas, United States
    I'm fairly certain you need to replace much more. I also have an 02, with 04 STi hubs (5x100). I was just looking into picking up some 06 STi hubs for the 5x114 bolt patters as well as upgraded bearings.. I was told I need to do the whole swap at once: STi 6-speed transmission, STi axles, R180 rear diff, drive shaft, hubs, shift linkage, etc.
    Jan 2011
    Phoenix AZ
    Really. Aw man. I was hoping I could just swap out the hubs and change the bolt pattern. Sounds like way too much to me. If you find out anything more or anyone else has any info please share. Thanks for theinput. Much appreciated
    Mt. Laurel, NJ
    ^ Yep. I'd read that in a bunch of places as well...that's why if you are swapping in a 6spd that isn't an 04 is very difficult as well.
    Registered User SKI.WRX's Avatar
    Jun 2010
    Colorado
    Unless you get custom axles made to mate the 114 hubs to the trans and diff I don't think there are stock axles that will fit
