Results 1 to 3 of 3
This is a discussion on 03 T-Stat replacement within the Request a Tutorial/DIY forums, part of the Tutorials & DIY category; At idle and while driving my temp gauge will almost touch the red zone then more times than not at ...
    Dec 2011
    At idle and while driving my temp gauge will almost touch the red zone then more times than not at a point it will go back down to operating temp. Fans kick in, and the vents blow cold air with the selector in the intake poshion and the heat dial turned to heat. so with that said I am asking for a tutorial on a t-stat replacement (location would be greatly appreciated). sorry lack of info 03 Subie wrx
    Registered User cjm1991's Avatar
    Jun 2009
    st louis
    Chris
    02 Camaro z28 T-Tops, m6 49k miles
    Bolt ons and tuned - 349rwhp/362rwtq
    02 Ws6 T-Top,m6 80k miles
    Bolt ons/Cam/tune - 436rwhp/424rwtq
    Buy an authentic Subaru thermostat, authentic Subaru coolant, and an authentic Subaru thermostat gasket. If your housing is pitted on the outside where the lower rad hose clamps, buy a new housing also. If the hoses are old, now's the time.
    You do not have to remove any fans and maybe if the guy in the link had not disassembled half his car in the cold he'd have less of an adventure.
    Drain the coolant, replace what needs replacing (see above), and burp the system.
    In fact, if the car just started doing this overheating thing recently and you've also recently opened up the cooling system for any reason, burp the system. You may not need any of this stuff.
