Results 1 to 6 of 6
This is a discussion on Help installing Escort Passport 9500ix within the Request a Tutorial/DIY forums, part of the Tutorials & DIY category; Hey all, I'm picking up my STI tonight and I just purchased a radar detector for it. Does anyone have ...
    Nov 2011
    Hey all,
    Does anyone have a guide on what I need to buy so I can install and wire it?
    Thx.
    JayCee
    Negative pantsy rage-wrx's Avatar
    Aug 2010
    Yonkers/NYC
    -Tony
    2011 WRX WRB Stage2
    2012 FXT DGM
    The Big 2011/2012 Mod Thread
    "Just Leave me alone. I know what I'm doing"-
    Kimi Räikkönen
    Nov 2011
    Hey Tony,
    Thx for the quick response.
    I'll definitely look into getting them.
    I've never opened up the car, you know where I can get some info on opening it up and installing the fuse wire?
    Thx again.
    -JayCee
    Registered User xFalleNx's Avatar
    Nov 2010
    Moorestown, NJ
    The fuse box is on the lower left side of the front dash, below the steering wheel. There's a little pull handle there to access the fuse box.
    --Anthony 2011 DGM WRX stg2+sf intake + custom front end deer mod!
    Official Subie owner as of 01/10/11
    Stink Eye Mob #87
    Bye bye Bimmer
    Hellooo '11 REX
    Aug 2010
    Yonkers/NYC
    The way I would go about this
    Use a trim removal tool,screwdriver,crimping tool,zip ties
    1.remove A-pillar trim(pop out the piece that says "srs air bag") & remove the screw to do this
    2.loosen headliner
    3.Pop out left side dash trim
    4.remove fuse box cover(left lower side below steering wheel)
    5.Route wire through headliner to the mirror> A pillar(zip tie wire out of the way of the air bag) > to the fuse box.
    5.use any 3 amp fuse which is only hot when the car is running.
    6.Install ground to chassis.(you need to get the appropriate spade or ring terminal)
    7.After crimping your hot wire to the Add-a-fuse ,connect it to the fuse
    7.Check to see that radar detector works(only when you start the car)
    8.Put everything back together & you are good to go.
    Also a good video by radarroy
    -Tony
    2011 WRX WRB Stage2
    2012 FXT DGM
    Kimi Räikkönen
    Quote Originally Posted by rage-wrx
    I did mine similarly, but tapped my DC outlet instead
    Sent from my Droid using Tapatalk
