Front differential(?) replacement
Results 1 to 5 of 5
This is a discussion on Front differential(?) replacement within the Request a Tutorial/DIY forums, part of the Tutorials & DIY category; 2003, 107xxx miles, showing all signs of a problem with front or center differential. On a scale of 1-10, how ...
    Registered User TrailerTrashed's Avatar
    Feb 2008
    Atlantic Beach, FL
    2003, 107xxx miles, showing all signs of a problem with front or center differential. On a scale of 1-10, how hard is it to tackle this myself, replacing the differential? If there's already a tutorial on this, I can't find it.
    Jul 2004
    Seattle, WA
    Are you having trouble with the Front Diff or the Center Diff? Pictured here in the lower right hand side is the front diff, as you can see the transmission case needs to come apart to get at it.
    The Center diff is located (not pictured) left of the gears, and is easier to get at.
    Edit: Here is some information on the center diff.
    http://www.subaruforester.org/vbulle...ce-them-46979/
    Registered User poly_poly-man's Avatar
    Feb 2010
    Rochester Institvte of Technorcery
    what problems are you getting?
    My big thread: The Used WRX Buying Checklist - Please Contribute!
    My current car: 2002 WRB WRX Wagon.
    Mods: GM BCS, Carberry SD rom, uppipe, AEM UEGO, Klunk Killer, F+R shifter bushings, head unit
    Feb 2008
    Atlantic Beach, FL
    Problems are: grinding under car only correlating to how fast the wheels are turning and binding/resistance with a clunk while turning at slow speeds. Am I wrong about the differential? viscus coupler?
    Had a new transmission installed so I've managed to rule that out.
    Registered User hachetman13's Avatar
    Jul 2011
    Fort Walton Beach, Florida, United States
    sounds like the transfer case to me there are videos on youtube you could compare your noise too and a few removal tutorials
