how much oil will be lost
Results 1 to 7 of 7
This is a discussion on how much oil will be lost within the Request a Tutorial/DIY forums, part of the Tutorials & DIY category; how much oil will be lost if i remove the oil line from the top of the turbo on a ...
    Jul 2011
    Rose Park, Utah, United States
    how much oil will be lost if i remove the oil line from the top of the turbo on a 2008 wrx i need to replace the accuatior
    Biohazard
    ClubWRX.net Vendor adam@kronosperformance's Avatar
    Nov 2005
    Princeton, NJ
    More than likely not much since it shouldn't be fully pressurized. If you lose some, just put some more in.
    Jul 2011
    ok ty cause the whole purpose of haveing to replace it is cause i installed a mbc and then i turnded the boost up a little and cant get it turned back down cause i experience boost creep in 4th and 5th gear so i purchased a accuator that will withstand 18psi and ya i was jw but thank you so much for your help also will a divorced wastegate dp help with boost creep it is a 3 inch high flow catted perrin dp
    Biohazard
    Nov 2005
    Princeton, NJ
    Boost creep has more to do with the wastegate itself than anything else.
    zax
    zax is offline
    Super Modulator zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    Quote Originally Posted by j-dogg View Post
    You shouldn't be "slapping on" a MBC on a 2008 WRX and just turning up the boost. While you could get away with it on Bugeyes, the newer 32 bit ECUs are much more finicky. Are you even tuned to run that downpipe???? That's the reason you have boost creep...
    Zax's Shaggin' Wagon (SOLD)
    Facebook me here
    Jul 2011
    im not tuned yet but i will be soon
    Biohazard
    Jul 2011
    i havent put the downpipe on yet i am this weekend
    Biohazard
