Results 1 to 2 of 2
This is a discussion on help fuel pump within the Request a Tutorial/DIY forums, part of the Tutorials & DIY category; i need a fuel pump sticky please help... (04 wrx with vf39 and supporting mods as soon as i find ...
    Registered User 04 STi CLoNe's Avatar
    May 2008
    San Diego
    help fuel pump
    i need a fuel pump sticky please help... (04 wrx with vf39 and supporting mods as soon as i find a sticky for fuel pump) already did injectors up and down pipe.
    UnBanned Sinister's Avatar
    Nov 2006
    Denver Metro Area
    on install?
    It's so easy it's not even funny...
    The fuel pump hatch is in your trunk.
    Pull the carpet up and it'll be on the right side next to the seat.
    Remove those bolts.
    There will be a foam pad. hold onto that.
    Next it's not a bad idea to pour some carb cleaner, etc on top of the fuel pump assembly's cover and let it sit for a minute or two to loosen it up.
    Then pull that off.
    Inside you'll see the fuel pump. It's completely self explanatory on how to remove and install the new pump.
    Save your old pump.. if I remember right walbro pays for oem fuel pump core's...
