I have a bunch of Subaru parts for sale. I will have even more for sale in later in the spring. This is what’s available now. Text me at 515-979-8711 for information or pictures.
Forester STI – Around 38,000 miles. These parts will be shipped from or picked up from central Iowa, just outside of Des Moines.
· IHI VF41 turbocharger. Spins great, the wheels can’t touch their housings.
· TY856WL4CC transmission - 3.636, 2.235, 1.521, 1.137, 0.891, 0.707, FD 3.9 Central diff Viscous. Comes with clutch, flywheel, and starter. Sold
· OEM catted downpipe
· OEM turbo heat shield with bolts
· Upper coolant reservoir with cap and lines
· Intercooler brackets
· Motor mounts
· Intake assembly – Intake manifold, electronic throttle body, TGV assembly, fuel injectors, rails, air inlet, ect.
· AC compressor – Denso lightweight
· Alternator
· Alternator belt cover
OEM post MAF intake hose
· EBCS
04 WRX – 100,000 miles. These parts will be shipped from or picked up from central Iowa, just outside of Des Moines.
· OEM crank pulley – Has around 30,000 miles on it.
· EBCS with bracket
· Turbo inlet with blue Samco BPV hose
· Turbo support brackets from the uppipe to the engine
· Catted uppipe – Has around 30,000 miles on it.
· Windshield reservoir with pump
· K&N Typhoon short ram intake kit – Has around 70,000 miles on it. Comes with the MAF sensor. Recently re oiled before removed.
· AC compressor – Calsonic. It worked great, no squeaking.
· AC lines with bolts
· Front bumper beam – Red
· 6 disk CD changer
· Rear view mirror with compass and dimmer.
· TMIC with OEM BPV and y pipe.
These are various used parts. These will be shipped from or picked up from Virginia Beach, Virginia.
· AEM e85 UEGO wideband air fuel ratio oxygen sensor and 52mm gauge - It has less then 1500 miles on it. It cost $223 when new.
· Catted uppipe from a 04 Subaru WRX removed with 36000 miles
· Cattless uppipe with 1 damaged stud
· WRX engine wiring harness
· WEDSSPORT TC105N FORGED LIGHT WEIGHT 5X114.3 WHEELS WITH NITTO TIRES – Wheel specs: Rear two - WedsSport TC105N 1pc Lightweight Forged One Piece Wheels - 18x10.5 - 5-114.3 - +12 18.4lbs $576 a piece. Front two - WedsSport TC105N 1pc Lightweight Forged One Piece Wheels - 18x9.5 - 5-114.3 - +35 17.6lbs $558 a piece. Tire specs: Rear two - 275/40-ZR18 Nitto NT01 - DOT approved competition tread depth 6/32 inch UTQG: 100 AA A Max load - 1709lbs @ 51 Max PSI $263 a piece. Front two - 245/40-ZR18 Nitto NT01 - DOT approved competition tread depth 6/32 inch UTQG: 100 AA A Max load - 1433lbs @ 51 Max PSI $223 a piece. They have only 15 miles on them from a 370Z. Slight damage on the front two wheels. This set cost $3240 without shipping or mount and balancing when new. On a Subaru they could be used for a RWD converted Sti.
These are various new parts. These will be shipped from or picked up from Virginia Beach, Virginia.
· 27011AA690 OEM rear differential 3.545 R160 Viscous LSD - For the 02-05 Impreza WRX. The code letters on the differential are EF and it comes with the original box. It's MSRP is $1633 with the core charge.
· H6300LS300 Subwoofer – For the 2003-2006 Subaru Baja, Legacy, and Outback. They Are $228 at the dealer.
· J5010LS400 rear cargo bin with dividers – For the 2002 - 2004 Outback and Legacy Wagon. SOLD!
· 57260AE00A and 57260AE01A hood hinges - It fits various 00-06 Subaru models.
· 45161AE00A top radiator hose
· 31705AA380 transmission valve body
· H6220FS000 cassette deck
· 333E145 graphic equalizer
· H7010FC001 cruise control – for 2.5 automatic Forester
· 35110AC300 shifter assembly
· A set of 4 rubber splash guards for the 95-99 Legacy.
· Motor mounts
· Alternator
· EBCS
· EBCS with bracket
· 6 disk CD changer
