Want To Buy Oil Pan for 02 WRX 2.0L turbo
Results 1 to 10 of 10
This is a discussion on Oil Pan for 02 WRX 2.0L turbo within the Personal For Sale & Wanted forums, part of the ClubWRX.net Marketplace category; So was driving down the highway, saw abunch of cows loose on the other side of the road. while looking ...
    Aug 2013
    Miles City, MT
    So was driving down the highway, saw abunch of cows loose on the other side of the road. while looking at them I glance forward to see a piece of a blown out tire infront of me, which i then run over. after that the road was scattered with the remains of atleast 2-3 tires, no kidding or exageration here. Then i see the cause of all the tire carnage, someone's fartcan had fallen off their vehicle and many people must have hit it. I unfortunately didni't have time to swerve to avoid it do i aim to protect my tires thinking that as smashed up as it was i should beable to make it... I was wrong!!
    It impacted on several parts of my undercarrage, the good news is it did no real damage to anything, except my oil pan. It bent the bottom up pretty good, not enough to cause damage to anything inside but enough to cause it to start leaking around the plug. I've sense sealed up the plug with silicone but i will need to replace the oil pan in the next 3 or so months, before my next oil change. I'm lucky in the fact that not more than 3 weeks ago i got my oil changed so it's a fresh batch.
    Anyway, I am looking for a deal on an Oil Pan, i've already priced around i cna get a Dorman replacement one for about $60 with shipping but anything i can save is more money i can use for other things, you know how it is i'm sure.
            MainFrame's Avatar
    Austin, TX
    You should upgrade to the pan and baffle for the 2.5L. The flat pan on the 2L has been shown to cause oil starvation while cornering.
    MainFrame, for future reference, do you recall whether the oil pickup is common to the two models, and what else might need to be changed for a swap?
            MainFrame's Avatar
    Austin, TX
    Good question.. I hadn't thought about it since I got a Killer B pickup to use when I upgraded the pan. They offer a different pickup for those with the ej20 pan, so I would assume a new pickup is pretty much required when changing pans (the ej25 pan is deeper, so that makes sense).
    I suppose when you factor in the cost of pan+pickup+baffle the cost may be a little high for someone who doesn't drive spiritedly. But if you like to drive your car hard, it's definitely worth the piece of mind to not be forcing air bubbles through your bearings.
    Also, the dip stick and tube are slightly different, so if you want it to read spot on you would need to change that too.. but I have never bothered to. I just put the right amount of oil in the car, and that's where I consider it "full".
    Thanks very much for clarifying, I appreciate it.
    Moderator Donkey's Avatar
    Da boonies,Va
    What is your zip? I got a 2.0L pan just need to figure out what shipping would be. Might be able to do $30 shipped.
    2002 FORESTER S
    1998 FORESTER S
    Aug 2013
    Miles City, MT
    Podunc MT 59301 is the zip
    Feb 2014
    Pmd..
    Sent from my SCH-I535 using Tapatalk
    Da boonies,Va
    I can do it for $30 shipped. Pm me if you are still in need of an oil pan.
    2002 FORESTER S
    1998 FORESTER S
    Registered User tirerob's Avatar
    Nov 2012
    bug-eyeing in the Bakken
    HEY! its about time you got on the club slacker! should be on more often than nailing debris and poking holes in your car hahahhaha
    when my friends come up, i hear, "you sold the camarrrroooh.....HOLY BLEEP A WRX!"
    Ya has that effect on me too.
    Rob
    Where did he go?? http://www.clubwrx.net/forums/builds...ll-thread.html
