For Sale impreza,wrx, and sti parts GC, GD, and GR parts BIG list
Page 1 of 4 1234 LastLast
Results 1 to 15 of 47
This is a discussion on impreza,wrx, and sti parts GC, GD, and GR parts BIG list within the Personal For Sale & Wanted forums, part of the ClubWRX.net Marketplace category; X4 04 wrx fuel rails side feeds 50 each one, if im wrong on info i will edit or post ...
    Apr 2013
    X4 04 wrx fuel rails side feeds 50 each one, if im wrong on info i will edit or post pl
    05 wrx maf sensor intake with inlet and airbox 150
    04 wrx td05 with $190 88,xxx This turbo is off a healthy running motor NOT a blown or seized engine. It does have some shaft play when force is applied while inspecting, however it did come off a running WRX.
    sti airbox resonator $25
    x2 wrx/sti turbo headers 80 in great condition no rust
    02-05 wrx/sti aluimunm turbo resiover 40 each
    99-01 rs 4:11 r160 175
    04 wrx r160 3:90 175
    02-05 wrx CF mirrors from ebay bnib payed 150 im asking 115 shipped
    05 sti front axles 250 for both
    05 sti clutch, and brake pedal
    05 sti dbw pedal
    02-07 wrx/sti stock crank damper for 50
    05 sti rods 45
    02-09 wrx-sti perrin recirc blow off valve 150 with flange but no plug
    wrx r160 3:54 190
    04 wrx front hubs/knuckles with bearings no play $100 no rust in great condition
    08 sti GR hubs/knuckles no bearing i have four im asking $200 20,xxx
    08 sti GR quad tip catback $250 in great condition no rust 20,xxx
    08 sti GR three full struts assembly one front and two rears im asking $300 for all three or 100 each no rust 20,xxx
    02-07 impreza bnib aftermarket radiator no turbo coolant hole perfect for rs car with none turbo 150
    05 sti front turbo crossmember 100
    05 sti all four hubs/knuckles
    02-03 wrx cluster one with 176,xxx for 45 and the other with 253,xxx for 35
    08 sti tmic with ypipe 350
    04 sti steering wheel and airbag with cruise control $250
    04 wrx job side skirts both side 250
    06 sti steering rack with inner rods cut off $160 or with bnib inner rod i can put on but im asking for 240
    02-05 wrx front calipers $50
    02-03 wrx cams DOHC turbo $100 for all four
    04 sti dohc cams the set 200 each
    catco 2'5 downpipe with cat $180 shipped brand new
    05 sti front brake lines Saintless steal russel $90 for both and i have a rear set also 90
    04-09 sti shortblock with 32,xxx $900
    05 sti all four strut assembly $350
    05 bbs rim all 05 and up for 5x114 for $700 with tires 215/45/17 brigestone potenza re92 with good tire tread
    02-03 wrx rear seats no cigarette burns in good conditon $80
    04 ej257 all four connecting rods $90
    greddy fmic for 01 rs $100
    04-05 sti door handle plastic surround all four one of them is cracked but with glue it will hold $20 for all four interior
    04 sti rear door cards item holder $10 for both rears
    04 sti front door swith surround and rear for door cards 25 $for both
    02-07 wrx/sti u brace subframe $100
    02-03 wrx scoop splitter seal $15
    04 sti Tbrac $75
    05 sti rear crossmember 80
    06 wrx heater core $50
    04 sti rear crossmember $75
    tein type S springs come off an 06-07 wrx with 5,xxx miles rears only $65 for both
    2 04 steering column $50
    05 sti door cards $225 for all four
    05 sti rear seats $250
    05 sti front reinforcement beam SOLD $30 for foam piece
    2 04 wrx/sti rear reinforcement beam $75
    05 sti carpet in mint condition 150
    All the side trim from an 04 sti lmk with an pm of what u need
    05 sti driver headlight $350 in mint condition no broken tabs comes with motor and harness
    04-05 sti fender darker silver $150 each
    05 sti hood psm $225 it has some dents but fixable
    05 sti front bumper dark silver $140 in mint condition
    04 sti all four doors with windows and motors also in good condition $200 for each door in wrb no dents
    PASSENGER REAR DOOR, DRIVER REAR AND DRIVER FRONT SOLD
    05 sti all four doors in psm i have all four sale 200 each no dents
    01 RS master cylinder $45
    04 sti crank damper $40
    01 rs heater core $45 SOLD
    04 sti PSM trunk $100 It has slight dent and crack on paint but easy to fix SOLDS
    04 sti trunk hinges $25
    04 sti wrb fog light covers $60 SOLD
    [/b]04 sti wrb trunk and spoiler $340 SOLD
    04 wrx oil pan with pick up tube 62,xxx $40 for both
    04 sti rear seat brace $25
    04 sti headlinear light $25
    04-05 sti trunk trim $60 for everything right, left, and middle trim
    04-05 sti interior trim, rear seats trim, side doors trim pm me for prices
    04 sti spare cover $25
    04 sti fuel tank door $20 in psm
    04 sti dbw TB $60
    94 legacy turbo Maf $50
    94 legacy turbo intake manifold $60 with injector
    95 legacy front and rear calipers with pads $90 for the whole set just SOLD REARS
    09 passenger side imperza rs n/a head w/variable valve with valve covers but no cams $100
    02/03 wrx rear seats with middle fold down hand rest $100 obo for both in good condition no cigarette burns
    two 02-05 wrx tmic no pipe with sti imprint $40 with some dent vents and the other in mint condition with y pipe asking 70
    04 sti PSM exterior door handles 20 for both side front
    04 sti headlight dome $25
    00 rs brake booster $60
    04-05 wrx skid plate $40
    02-03 wrx tailights $90
    02-03 cluter gauge $60 yellow mark needles
    05-07 outback xt or legacy gt engine cover $75
    05-06 outback xt or legacy gt plastic intake manifold $120
    subaru steering make an offer 93-01 subaru
    plus im open to trade 235/45/17 or 245/40/17 a set of four tires, arp studs, tmic bracket, BBs with snow tires 5x100 something that clears brembos, 05 sti engine and dash harness i will think more later
    05 sti psm complete part out watever is listed is all i have
    95 L awd coupe automatic with a 4:11 and 2.2L part out dark green manual locks and windows
    plus i have a 01 rs part out it is not complete part out just some stuff here is the link
    more to list and more part
    1 set of 06-07 Wrx TR door cards ( black n gray) 100.00 or b.o
    1 96 JDM STI ej20g ecu 120.00 or b.o
    1 full set of JDm EJ20g cam sprockets 100.00 or b.o
    1 full set or 95-99 Legacy outback cam sprockets 80.00
    1 04 Sti ECU , not locked, or bricked 250.00
    1 set of Cometic ej22t head gaskets, .056" 60.00 or b.o
    1 complete intake manifold w/ all sensors, injectors & coil pak off 99 Leggy outback 2.5 DOHC 125.00 or b.o
    1 4:11 LSD rear diff out of a 99 R.S 180.00 or b.o
    1 3.54 LSD rear diff out of a 03 wrx 180.00 or b.o
    4 crank sensors 20.00 ea
    4 wrx cam sensors 20.00 ea
    4 STi cam sensors 20.00 ea
    1 set (f/r)02^ WRX ABS sensors 40.00
    1 02-03 Wrx front & engine harness w/ecu (5 spd) 250.00
    1 set ( all 4 corners) 02 Wrx hubs/knuckles 180.00 pik up only
    1 APS fmic bumper beam , has some rust, 50.00 or b.o
    1 05-07 Sti ABS control unit 80.00 or b.o
    2 02-05 WRX ABS control unit 60.00
    1 02 wrx power steering pump w/ reservoir 68k 90.00 or b.o
    1 02-07 Wrx/STi combo switch, (sedan) 35.00
    1 Lamco boost gauge installed on steering cover 80.00
    1 02-05 WRX OEM pressure plate & clutch disc less than 8 k on it ! 170.00 or b.o
    1 set of 99-01 R.S heads, 74k w/3 bent valves 200.00 or b.o
    1 Set of 99 O.B cyl heads (Ej25D)w/ cams,complete ,approx 63k VGC 200.00 or B.O
    1 04-17 STi oem flywheel 30k , great condition 65.00 or b.o
    1 Innovate XD-16 Wideband gauge 60.00 or b.o
    3 02-05 wrx coolant header tanks 25.00 ea
    2 5 spd shifters/linkage 25.00 ea.
    1 V7 MOMO drivers side air bag only 50.00
    1 Gm boost solenoid w pigtail 30.00
    1 Full set of 2.0 cam gears, no broken teeth or cracks 90.00 for the set, not willing to separate
    ? Misc Sti & wrx Camshafts.. not complete sets Make an offer
    3 L/s intake cam gears 25.00 ea
    3 R/s intake cam gears 25.00 ea
    2 06-07 wrx oil coolers 60.00 ea.
    1 05 ^ (08)Wrx/LGT plastic manifold only 75.00
    1 set of 02-03 wrx rear tail light tinted 80.00
    1 06-07 wrx clock pod w/ built in Wide band gauge in red led 75.00
    Apr 2013
    pm wat u need i just may have it thanks everyone
    Apr 2013
    more to list
    Apr 2013
    bump...
    Registered User silvercookie's Avatar
    Aug 2009
    Glendale, NY
    where are you located?
    Apr 2013
    Quote Originally Posted by silvercookie View Post
    chicagoland I will be updated the list and making it more organized soon
    Registered User BEASTmode632's Avatar
    Nov 2012
    Chatlotte, NC
    What color is the perrin recurc valve? And will it not fit a 2010?
    2015 Subaru WRX : ISC Coilovers........
    Apr 2013
    it is black part number shows for 02-09 wrx/sti so no i dont think so
    Palmyra, NJ
    Any exhausts from a GC?
    GF's Outback Sport needs one!
    May 2012
    PM'd you
    Apr 2013
    stock or aftermarket?
    Apr 2013
    sold bumpers, fenders, crank, one rods, NA headers, 05 sti rear crossmember, side skirts more to list later
    Jul 2013
    Hey I'm looking for some parts, can u call me or I call u...
    Quote Originally Posted by 01rstiimpreza View Post
    two set of sti 5x114 enkei rpf1 in silver 17x9 35mm offset with bfgdrich racing comp tires im asking $1200 each a set with tires pm me for pics
    X4 04 wrx fuel rails side feeds 50 each one, if im wrong on info i will edit or post plz
    N/A header 60 very clear no rust of a 03 wrx sohc
    06 sti rear brembos with rotors 5x 114 im asking 550 plus shipping and paypal fees
    05 sti dbw pedal
    05 sti oil pan 40 no dip stick
    05 sti rods 90
    wrx r160 3:54 190
    05 sti spare 5x114 60 in mint condition
    04 sti driverside side skirt wrb $75
    04-09 sti shortblock with 32,xxx $1000
    JUST GOT IN 06 sti 6 speed with 16,xxx with clutch, clutch fork, trans mount, and shifter 2900 pick up
    04 sti Tbrac $75
    04 sti dbw TB $60
    Palmyra, NJ
    Holy hell man, sorry I just now saw that you had replied! My bad!
    Stock or aftermarket...her muffler fell off and is just a straight pipe right now lulz.
    Apr 2013
    more hp lol how does it sound? catted?
