impreza,wrx, and sti parts GC, GD, and GR parts BIG list
For Sale
7K views 46 replies 15 participants last post by  BrewCrew
#1 · (Edited)
X4 04 wrx fuel rails side feeds 50 each one, if im wrong on info i will edit or post pl
05 wrx maf sensor intake with inlet and airbox 150
04 wrx td05 with $190 88,xxx This turbo is off a healthy running motor NOT a blown or seized engine. It does have some shaft play when force is applied while inspecting, however it did come off a running WRX.
sti airbox resonator $25
x2 wrx/sti turbo headers 80 in great condition no rust
02-05 wrx/sti aluimunm turbo resiover 40 each
99-01 rs 4:11 r160 175
04 wrx r160 3:90 175
02-05 wrx CF mirrors from ebay bnib payed 150 im asking 115 shipped
05 sti front axles 250 for both
05 sti clutch, and brake pedal
05 sti dbw pedal
02-07 wrx/sti stock crank damper for 50
05 sti rods 45
02-09 wrx-sti perrin recirc blow off valve 150 with flange but no plug
wrx r160 3:54 190
04 wrx front hubs/knuckles with bearings no play $100 no rust in great condition
08 sti GR hubs/knuckles no bearing i have four im asking $200 20,xxx
08 sti GR quad tip catback $250 in great condition no rust 20,xxx
08 sti GR three full struts assembly one front and two rears im asking $300 for all three or 100 each no rust 20,xxx
02-07 impreza bnib aftermarket radiator no turbo coolant hole perfect for rs car with none turbo 150
05 sti front turbo crossmember 100
05 sti all four hubs/knuckles
02-03 wrx cluster one with 176,xxx for 45 and the other with 253,xxx for 35
08 sti tmic with ypipe 350
04 sti steering wheel and airbag with cruise control $250
04 wrx job side skirts both side 250
06 sti steering rack with inner rods cut off $160 or with bnib inner rod i can put on but im asking for 240
02-05 wrx front calipers $50
02-03 wrx cams DOHC turbo $100 for all four
04 sti dohc cams the set 200 each
catco 2'5 downpipe with cat $180 shipped brand new
05 sti front brake lines Saintless steal russel $90 for both and i have a rear set also 90
04-09 sti shortblock with 32,xxx $900
05 sti all four strut assembly $350
05 bbs rim all 05 and up for 5x114 for $700 with tires 215/45/17 brigestone potenza re92 with good tire tread
02-03 wrx rear seats no cigarette burns in good conditon $80
04 ej257 all four connecting rods $90
greddy fmic for 01 rs $100
04-05 sti door handle plastic surround all four one of them is cracked but with glue it will hold $20 for all four interior
04 sti rear door cards item holder $10 for both rears
04 sti front door swith surround and rear for door cards 25 $for both
02-07 wrx/sti u brace subframe $100
02-03 wrx scoop splitter seal $15
04 sti Tbrac $75
05 sti rear crossmember 80
06 wrx heater core $50
04 sti rear crossmember $75
tein type S springs come off an 06-07 wrx with 5,xxx miles rears only $65 for both
2 04 steering column $50
05 sti door cards $225 for all four
05 sti rear seats $250
05 sti front reinforcement beam SOLD $30 for foam piece
2 04 wrx/sti rear reinforcement beam $75
05 sti carpet in mint condition 150
All the side trim from an 04 sti lmk with an pm of what u need
05 sti driver headlight $350 in mint condition no broken tabs comes with motor and harness
04-05 sti fender darker silver $150 each
05 sti hood psm $225 it has some dents but fixable
05 sti front bumper dark silver $140 in mint condition
04 sti all four doors with windows and motors also in good condition $200 for each door in wrb no dents
PASSENGER REAR DOOR, DRIVER REAR AND DRIVER FRONT SOLD
05 sti all four doors in psm i have all four sale 200 each no dents
01 RS master cylinder $45
04 sti crank damper $40
01 rs heater core $45 SOLD
04 sti PSM trunk $100 It has slight dent and crack on paint but easy to fix SOLDS
04 sti trunk hinges $25
04 sti wrb fog light covers $60 SOLD
[/b]04 sti wrb trunk and spoiler $340 SOLD
04 wrx oil pan with pick up tube 62,xxx $40 for both
04 sti rear seat brace $25
04 sti headlinear light $25
04-05 sti trunk trim $60 for everything right, left, and middle trim
04-05 sti interior trim, rear seats trim, side doors trim pm me for prices
04 sti spare cover $25
04 sti fuel tank door $20 in psm
04 sti dbw TB $60
94 legacy turbo Maf $50
94 legacy turbo intake manifold $60 with injector
95 legacy front and rear calipers with pads $90 for the whole set just SOLD REARS
09 passenger side imperza rs n/a head w/variable valve with valve covers but no cams $100
02/03 wrx rear seats with middle fold down hand rest $100 obo for both in good condition no cigarette burns
two 02-05 wrx tmic no pipe with sti imprint $40 with some dent vents and the other in mint condition with y pipe asking 70
04 sti PSM exterior door handles 20 for both side front
04 sti headlight dome $25
00 rs brake booster $60
04-05 wrx skid plate $40
02-03 wrx tailights $90
02-03 cluter gauge $60 yellow mark needles
05-07 outback xt or legacy gt engine cover $75
05-06 outback xt or legacy gt plastic intake manifold $120
subaru steering make an offer 93-01 subaru
plus im open to trade 235/45/17 or 245/40/17 a set of four tires, arp studs, tmic bracket, BBs with snow tires 5x100 something that clears brembos, 05 sti engine and dash harness i will think more later
05 sti psm complete part out watever is listed is all i have
95 L awd coupe automatic with a 4:11 and 2.2L part out dark green manual locks and windows
plus i have a 01 rs part out it is not complete part out just some stuff here is the link
more to list and more part
1 set of 06-07 Wrx TR door cards ( black n gray) 100.00 or b.o
1 96 JDM STI ej20g ecu 120.00 or b.o
1 full set of JDm EJ20g cam sprockets 100.00 or b.o
1 full set or 95-99 Legacy outback cam sprockets 80.00
1 04 Sti ECU , not locked, or bricked 250.00
1 set of Cometic ej22t head gaskets, .056" 60.00 or b.o
1 complete intake manifold w/ all sensors, injectors & coil pak off 99 Leggy outback 2.5 DOHC 125.00 or b.o
1 4:11 LSD rear diff out of a 99 R.S 180.00 or b.o
1 3.54 LSD rear diff out of a 03 wrx 180.00 or b.o
4 crank sensors 20.00 ea
4 wrx cam sensors 20.00 ea
4 STi cam sensors 20.00 ea
1 set (f/r)02^ WRX ABS sensors 40.00
1 02-03 Wrx front & engine harness w/ecu (5 spd) 250.00
1 set ( all 4 corners) 02 Wrx hubs/knuckles 180.00 pik up only
1 APS fmic bumper beam , has some rust, 50.00 or b.o
1 05-07 Sti ABS control unit 80.00 or b.o
2 02-05 WRX ABS control unit 60.00
1 02 wrx power steering pump w/ reservoir 68k 90.00 or b.o
1 02-07 Wrx/STi combo switch, (sedan) 35.00
1 Lamco boost gauge installed on steering cover 80.00
1 02-05 WRX OEM pressure plate & clutch disc less than 8 k on it ! 170.00 or b.o
1 set of 99-01 R.S heads, 74k w/3 bent valves 200.00 or b.o
1 Set of 99 O.B cyl heads (Ej25D)w/ cams,complete ,approx 63k VGC 200.00 or B.O
1 04-17 STi oem flywheel 30k , great condition 65.00 or b.o
1 Innovate XD-16 Wideband gauge 60.00 or b.o
3 02-05 wrx coolant header tanks 25.00 ea
2 5 spd shifters/linkage 25.00 ea.
1 V7 MOMO drivers side air bag only 50.00
1 Gm boost solenoid w pigtail 30.00
1 Full set of 2.0 cam gears, no broken teeth or cracks 90.00 for the set, not willing to separate
? Misc Sti & wrx Camshafts.. not complete sets Make an offer
3 L/s intake cam gears 25.00 ea
3 R/s intake cam gears 25.00 ea
2 06-07 wrx oil coolers 60.00 ea.
1 05 ^ (08)Wrx/LGT plastic manifold only 75.00
1 set of 02-03 wrx rear tail light tinted 80.00
1 06-07 wrx clock pod w/ built in Wide band gauge in red led 75.00
See less See more
You have insufficient privileges to reply here.
