I'll take the front pads, mine have nothing left.. I'm fairly certain they will fit for me.
Paypal USPS flat rate?
This is a discussion on Performance parts + Wheels/Tires + Body parts + Misc stuff + Free misc stuff. within the Personal For Sale & Wanted forums, part of the ClubWRX.net Marketplace category; Prices DO NOT include shipping. Performance Parts 1. Brand new HKS Super Mega Flow Short ram intake. 5. 2. Lightly ...
Performance Parts
1. Brand new HKS Super Mega Flow Short ram intake. $165.
2. Lightly used Injen short ram intake with Injen/Amsoil dry filter. - $75
3. TurboXS Manual Boost Controller. 0-30psi adjustable. Lightly used. - $75
Link - TurboXS High Performance Boost Controllers BC-HPBC - SummitRacing.com
4. BNIB Grimmspeed EWG up-pipe. Up-pipe only, no hardware or dump tube. One of the Studs is at a ~1-2* angle from when the hole was tapped. Will fit with some wiggling. $175 ($155 cheaper than new).
5. TD04 Forge Wastegate Actuator. Comes with blue spring installed. I believe you can buy other plates to fit other turbo's. Good alternative to going external wastegate. - $100
6. Internal Wastegate Actuator for a TD04, not a stock one, aftermarket with a stiffer spring. - $50
8. TurboXS H-34 Recirc valve. Comes with 90* elbow and tmic adapter. You will need to make a hose extension for the recirc hose. - $100
9. Random MAF housing. looks to be ~75mm. Good if you need to whip up a quick intake for cheap. $10
10. Gates racing radiator cap. - $2 or a Monster.
Body Part's
2. 02-03 PSM grill end caps - $30.
Wheels/Tires
Set of 02-04 wrx wheels. 3 wheels have Blizzak LM-25's with alot of life left. 1 has some all season that is almost dead.
1 rim has a bend. others are good. some scratches and curb rash. $150.
Set of Dunlop SP-Sport 01's. 235/45/17. used for ~7-8k miles. Lots of life left. 2 fronts have some camber wear. -$250
Misc. Stuff
1. Cyber Speed Grounding kit in Blue. This is wiring only. $20.
2. Autometer Pro-Comp Ultra-Lite boost gauge. Gauge only, no hose. 0-35 PSI. - $15.
5. Header and Header to 2 Bolt up-pipe gaskets - $25
6. 3 Bolt up-pipe gasket. $10
Free Misc. Stuff.
Omori oil pressure/temp sending unit. not 100% sure if it works as i never got the gauge with it, hence why it is free. pay shipping if not local.
Is the boost gauge boost/vac or just boost?
Got the pads, that was quick!
Thanks again.
I will take the Omori oil pressure/temp sending unit if it is still available.
PM me.
Thanks.
