transmission swap
Results 1 to 12 of 12
This is a discussion on transmission swap within the Personal For Sale & Wanted forums, part of the ClubWRX.net Marketplace category; i have a 02 wrx and i wanna get a newer one but i dont know which years will fit ...
    Jun 2009
    dover, afb
    transmission swap
    i have a 02 wrx and i wanna get a newer one but i dont know which years will fit or where to find one any where near by. if you have one i am looking to buy it if its within a reasonable price.
    zax
    zax is offline
    Super Modulator zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    Moving your WTB thread to the correct sub-forum
    Zax's Shaggin' Wagon (SOLD)
    Facebook me here
    zax
    zax is offline
    Nov 2008
    All WRX transmissions will be "bolt on" though you'll need an 06/07 rear diff to utilize those year transmissions. STi 6spd transmissions are swappable but will require (in some cases) an r180 rear diff, STi half-shafts, and a 4EAT driveshaft. No option is cheap and many rebuild instead. If I may ask, what is wrong with your current tranny and what's your budget for a resolution?
    Facebook me here
            MainFrame's Avatar
    Austin, TX
    I feel an 07+ six speed is the best of the bunch strength/gear ratio wise.. you're looking at probably $6000+ to get it all done.
    Jun 2009
    dover, afb
    well i just burned out my clutch after i put in new injectors and a bigger turbo and one its just old and two the gears are going out especially first gear but it was bad when i got it a few years ago. im looking to spend as little a possible but i know its going to be pricey but i wanna do a swap that will require the least amount of work. so if i can get one that will just bolt straight on that would be the best possible solution.
    zax
    zax is offline
    Nov 2008
    Quote Originally Posted by smugglin1986 View Post
    How do you know the gears are "going"? Generally the gears are broken or they aren't broken. I would suggest to replace the clutch and move forward. What turbo did you install? FWIW the 2003-2007 WRX uses the same gearset so it wouldn't be a worthwhile upgrade.
    Facebook me here
            MainFrame's Avatar
    Austin, TX
    Maybe worn out syncros?
    Jun 2009
    dover, afb
    it could be due to the fact first gear dosent like to engage unless im stopping at a slow speed or going to second then first
    Palmyra, NJ
    So the transmission doesn't like to go into 1st gear when its at a full stop? Bent fork perhaps?
            MainFrame's Avatar
    Austin, TX
    This sounds like every other 5mt that was not assembled with the dual cone first gear syncro..
    zax
    zax is offline
    Nov 2008
    You need to rev match. This is true for nearly every car, even those with dual ring synchros. There is nothing wrong with your transmission.
    Facebook me here
    Jun 2009
    dover, afb
    thanks for all the help
