WaveRV II wireless card, 1 MILE RANGE - eBay (item 320400792342 end time Jul-25-09 13:12:34 PDT)
BUY IT NOW: $100(Free Shipping)
Or you're welcome to bid: Starts at $75 (Free Shipping)
Model#
WAVERVII
- RV WiFi System-
WaveRV Specifications
Bus Type USB Version 1.1 - 2.0
Maximum USB Cable Length
Maximum USB Cable Length 16 feet
Longer length possible with USB Extension cable (sold separately)
Wireless Standard 802.11b, 802.11g/Super g
Operating Frequency 2400 to 2484 MHz (Ch 1-11 US)
International Version Available
Data Rate
802.11b: 11Mbps/5.5Mbps/2Mbps/1Mb
ps (with automatic adjust)
802.11g: Up to 108Mbps/54Mbps/48Mbps/36Mb/
24Mbps/28Mbps/9Mbps/6Mbps(with automatic adjust)
Modulation 802.11b: DSSS (Direct Sequence
Spread Spectrum)
802.11g: OFDM (64-QAM/16-QAM/QPSK/BPSK)
Operating Power 5.0V (USB Only)
Average Current 355 mA
Peak Current 500 mA (USB Compliant)
Transmit Power (ERP)
802.11b: 200mW (23dBm)
802.11g: 100mW (20dBm)
Receive Sensitivity
802.11b: -91dBm (typical) at 11Mbps
-91dBm (typical) at 6Mbps
802.11g: -76dBm (typical) at 54Mbps
-96dBm (typical) at 1Mbps
Working Range Outdoor: Up to 5825 ’ (more possible with external antenna connection)
@11Mbps, 5820 ’ (1 Mile) @
1Mbps
Security 64/128-bit WEP (Wired Equivalent Privacy)
WiFi Protect Access WPA-WPA2 (AES, 64, 128, 156-bit WEP with shared key protect access)
Antenna 5dB External Omnidirectional
Wibberduck Antenna
Antenna Vertical Beamwidth 35 degrees
Antenna Horizontal Beamwidth 360 Degrees
Operating Temperature -20 deg C to 45 deg C
Storage Temperature -30 deg C to 70 deg C
Humidity 10-95%, Non-Condensing
Dimensions WaveRV II: 2 3/4" x 1 7/8" x 1/2"
Wibberduck Antenna: 6 7/8" x 3/8" diameter
Weight 3 oz. (USB Cable not factored into weight)
Color Colors May Vary
Certifications FCC Part 15/UL, ETSI CE
