ca: POWERSLOT BIG ROTOR BRAKE KIT
Results 1 to 2 of 2
This is a discussion on ca: POWERSLOT BIG ROTOR BRAKE KIT within the Personal For Sale & Wanted forums, part of the ClubWRX.net Marketplace category; up for sale, set of front and rear powerslot(aem) big ROTOR brake kit with all mounting hardware. slightly used but ...
    Registered User anthonyrb98's Avatar
    Dec 2003
    Memphis, TN
    up for sale, set of front and rear powerslot(aem) big ROTOR brake kit with all mounting hardware. slightly used but in excellent condition. the affordable big brake system! asking $550 shipped obo. these retail close to $800 brand new for a front and rear set! THESE DO NOT INCLUDE CALIPERS. YOU USE YOUR STOCK CALIPERS with this system.
    from powerslot's website:
    Introducing the Power Slot Plus Big Brake System. The Power Slot Plus system uses a larger diameter, premium quality Power Slot brake rotor combined with your original factory brake calipers. Our patented caliper relocation brackets space the factory caliper further away from the hub to accommodate our oversized brake rotor. This increases brake torque force without affecting pedal effort or travel. The larger rotor is also a more effective heat sink, absorbing the heat generated under heavy braking. This greatly reduces brake fade and provides consistently shorter stopping distances, especially from higher speeds.
    NOTE: All Power Slot Plus brake kits require the use of larger diameter wheels. Check the dimensions of your wheels carefully before purchasing.
    pic of rotors: (note*all hardware included, just not pictured)
    KEY FEATURES:
    · Premium quality, larger diameter Power Slot rotor
    with Vac-U-Slot technology
    · Relocates the factory brake caliper for increased
    braking effectiveness
    · No special brake pad sizes required. Just use an original equipment-
    sized high performance pad (sold separately)
    · Patented design U.S. Patent # 6,305,509
    some sample pics (they fill the wheels very nicely):
    2002 wrx silver
    Registered User djerickd's Avatar
    Jun 2001
    Tampa, FL
    u still got these? are you not on nasioc anymore?
    SnowMann Tuned
    special thanks to:
    www.Aquamist.co.uk
