The Official Southern Oregon Thread - Page 65
Page 65 of 187 FirstFirst ... 15555657585960616263646566676869707172737475115165 ... LastLast
Results 961 to 975 of 2805
This is a discussion on The Official Southern Oregon Thread within the North Western States forums, part of the Regional Discussion category; all said, free is free..... slap it on, if you don't like it, swap them back... only your wrench time ...
  1. #961
    Registered User Essvar's Avatar
    Mar 2004
    Methford, OR
    all said, free is free..... slap it on, if you don't like it, swap them back... only your wrench time to lose. However, time is of the essence here because all the work needs to be done before my insurance company completes the claim.
    Life is a b!tch, so smack it on the ass and say "Thanks for the ride"
  3. #962
    Registered User Wade-0's Avatar
    Dec 2002
    Southern Orygun
    Quote Originally Posted by the_black_one
    Does the RS have stock springs/struts?
    Yes
    Cause I was was thinking my suspension, which doesn't have much body roll at all, may make a 20mm worthwhile. from what I know and have heard, the rear sway has a much bigger influence on understeer vs. oversteer. I haven't spun out with my 18mm, so maybe I could use 20mm? I noticed a large improvement in turn-in after upgrading from 13 to 18mm, but I also realize the difference in stiffness between 13 and 18 is about the same as between 18 and 20. So maybe an adjustable 18-22mm bar is the best way to go in my case.
    It's easy enough to experiment, and ultimately it's going to boil down to personal preference, but you are talking about a 9mm difference between front and rear which is pretty steep. If you're still taking your car on dirt roads, you might not want to go with anything bigger since you are removing independence from the suspension. Maybe stiffer springs are in order? And have you upgraded the endlinks, or are you still using the stock ones? That can make a huge difference too.
    This time of year people usually set their adjustable bars to the lowest setting, or swap their stock bars back on. I'm actually going to drop mine down a notch this weekend. Last year I left it on the middle setting and the car was pretty tail happy in the snow. I had a close one last winter while coming around a gentle bend in the highway doing about 40 in 4-5" of snow. As I backed off the throttle a little bit the rear end started coming around until the car was basically sideways. That was with snow tires on too. Luckily I recovered fairly quickly and there was no cleanup necessary in the shorts department.
  4. #963
    Feb 2005
    A.shleezy
    Quote Originally Posted by Wade-0
    Yes
    Stock front sway 93-01 is 19mm afaik. And I couldn't possibly find much stiffer springs. I've got kartboy rear links and noltecs in the front. And unfortunately, I don't have as much power nor throttle response as you may to worry about.
    So I may just give give it a whirl.... like essvar said (I won't try to remember actual names- as I have screwed up before), free is free. It's easy enough to swap back. Or would you need a sway bar to replece it?
    Also, I realize this isn't the best season to try this out- so maybe I'll just nab it for summertime.
    Don't you bring that weak tot action
  6. #964
    Mar 2004
    Methford, OR
    I will need a swaybar to replace mine with... as long as it looks stock(ish) to the insurance people that's all that matters..........
  7. #965
    Dec 2002
    Southern Orygun
    That wouldn't be a bad setup then, I thought you said you had a 13mm up front. What are your alignment specs?
  8. #966
    Feb 2005
    A.shleezy
    not so sure... no crazy camber for autocross or anything- just whatever the cowboy has in their comp. for subarus...
    I'd have to get my old bar from home on thanksgiving... I hope thats not too late.
  9. #967
    Dec 2002
    Southern Orygun
    I have the stock bar from my wife's RS I could spot ya. I don't plan on ever putting it back on.
  10. #968
    Mar 2004
    Methford, OR
    Since I just had to spot $550 out of pocket to get my car out of impound/towing yard i'm going to try to get the claim settled soon so I can be reimbursed. This week or next would be preferable if you have the time to wrench, if not just drop off yours and i'll just do the swap while i'm f'n with all the other stuff i'm swapping out.
  11. #969
    Feb 2005
    A.shleezy
    Doesn't take more than a few minutes, so I think I could fit it in.
    I've got an interview tomorrow @ ~1pm - so this weekend would be best. Exactly where in the land of meth do you reside?
    I may finally have a job (at the ashalnd oil stop) :woot:
    wish me luck.
  12. #970
    Mar 2004
    Methford, OR
    I'm at home anytime after 3:30, m-f or i'll be around on Sunday... PM me when you want to come out
  13. #971
    Feb 2005
    A.shleezy
    werd -- will do
  14. #972
    Feb 2005
    A.shleezy
    sorry. this is too good not to share - hope y'all haven't seen it already.
    http://www.viralmusicvideo.com/
  15. #973
    Registered User carrman's Avatar
    Oct 2005
    Medford, the final frontier
    Quote Originally Posted by Essvar
    Let's see, I spotted carrman today in medford (i was in my roomates exploder so he didn't see) and I also spotted Bo's old sedan and it sure sounded like that HKS exhaust was still on it....
    Where'd ya see me? Car was at DHM for a while on Wed. getting poly rack bushings to cure the memory steer. Works pretty good. Hella 500's came in UPS today, Cobb AP will be here tomorrow.....;-)
  16. #974
    Oct 2005
    Btw Wade, I have a stock bypass valve now and sold the BOV to some guy on the east coast. Proceeds went in to my Cobb AP fund.....;-)
  17. #975
    Mar 2004
    Methford, OR
    Quote Originally Posted by carrman
    Spotted you again today, on Roberts Rd.... Sipp'n a big gulp
