The Official Southern Oregon Thread - Page 149
This is a discussion on The Official Southern Oregon Thread within the North Western States forums, part of the Regional Discussion category; FIRST mod would be return to stock Bypass valve. If you already have COBB stage 1, where is your AP?? ...
  1. #2221
    Moderator T0rque's Avatar
    Dec 2004
    Medford, Oregon
    FIRST mod would be return to stock Bypass valve. If you already have COBB stage 1, where is your AP?? Did they not give you the AP when you bought it? Yea you can usually find them used for around 450
    Lead Wrench @ WTF Tuning, LLC
  3. #2222
    Registered User HONSUBY's Avatar
    Nov 2005
    CENTRAL POINT
    YES REMOVE THE BOV!!!!!! do you notice that wierd hesitation to boost after a shift and how ruff the accelleration is after a shift? ---its mainly because of the bov. going atmospheric is messing with the maf's readings and causing an intermittent lean condition everytime you shift. also (correct me if im wrong) but doesnt an intake cause an additional lean condition? --unless tuned to correct? thats wierd that you have a cobb tune without an access port.....to reflash again dont you have to have the exact unit used to flash to remove or change the flash?---chime in here guys he needs to figure this out, before he damages something.----plus that thing is gonna run sooooo much better on a stg 2 map!
  4. #2223
    Registered User <NicK>'s Avatar
    Mar 2007
    Medford
    I was really lucky, I have pretty much every single peice of paper on the car (mods, oil changes ect ect) since it rolled off the lot. In fact, I have all the paperwork from when the car was bought brand new back in 02. Anyway, There is an invoice from 2002 for a HKS SSQ bov. So odds are that its have this bov since 02
    And the invoice from Cobb, looks like he took the ecu out, sent it into Cobb, they reflashed it and sent it back.
    Its a short ram kinda style intake if that makes any difference.
    I havent really noticed any hesitation after I shift, but I am still getting used to the subi transmission. And I dont get on it very often mainly cuz my babies riding in the back most of the time.
    But the other day getting on 5 from work, it peaked at 16.5lbs in third. It was quite nice.
    02 COBB STAGE 1.5 WRX- Sold
    06 Mercedes C230 6-Speed (No it's not fast lol)
  6. #2224
    Registered User Essvar's Avatar
    Mar 2004
    Methford, OR
    The BOV will cause you to run rich b/w shifts and the intake will tend to lean the MAF out.
    Something doesn't jive b/c COBB reflash has the accessport to go with, other ECU reflashing like ECUtek goes straight into the ecu. Regardless with those mods you need a stage 2 map and to remove that BOV asap.... I would also suggest going back to a stock intake.
    But hell, what do I know... I'm just a motorcycle riding, short bus riding window licker.
    Life is a b!tch, so smack it on the ass and say "Thanks for the ride"
  7. #2225
    Dec 2004
    Medford, Oregon
    ^^ tater head???? Do you wear your helmet off your bike too!? j/k
    That is weird, but back in 02 maybe they didnt have the accesport yet. Maybe you had to send the ecu off like HONDATA.
  8. #2226
    Mar 2007
    Medford
    sooo... stage 2 Includes the ap?
    will it pretty much be a plugin and go thing? or will I hafta egt it dyno'ed?
    The easiest way is what I want, plus I really can't have any down time on the car, cuz of the baby and driving around the family n' such.
    I'm gonna shoot an email to Cobb, cuz it was def relflashed and sent back... I found the fedex slip in with the papers.
  9. #2227
    Dec 2004
    Medford, Oregon
    COBB Package stage 1 and stage 2 as of now and even 3 years ago came with an AP with is a plug and play mod.
  10. #2228
    Nov 2005
    CENTRAL POINT
    thanks for clearing that up essvar..... nick if you dont have the original bov, hks makes a recirc kit for the ssq.......the access port install is cake, it takes like 5 mins and your on the road again. also just get a k&n drop in for the intake and ditch the aftermarket crap.
  11. #2229
    Dec 2004
    Medford, Oregon
    ^ +1 The factory by pass valve can handle about 20psi from what Ive heard, also the factory air box is good up too 400 HP but you'll blow the tranny before that.
  12. #2230
    Registered User Wade-0's Avatar
    Dec 2002
    Southern Orygun
    Geez noobs! Cobb used to just sell an ECU reflash like EcuTek. It was called AccessECU. They offered an upgrade discount to existing customers when they launched the AccessPort. You should check with them, they might still cut you a deal.
  13. #2231
    Dec 2004
    Medford, Oregon
    Quote Originally Posted by LPPTundWRX View Post
    ^ ^ ^ Im no n00b
  14. #2232
    Mar 2007
    Medford
    I called up Cobb in Utah yesterday... and it is the ACCESSecu. It was all done in 8/02/03
    It was $419 (w/shipping)
    to get a stage 2/ap he said $650
    I'm going to take a pic of my intake... it looks like the oem black intake w/ a small aluminum peice that the hks filter goes onto... its weird
    any links for the hks reserculation (sp) kit?
  15. #2233
    Dec 2002
    Southern Orygun
    You should find out if Cobb can tell you anything about the map they reflashed your ECU with. I wouldn't just start pulling stuff, you might actually have a map that's been adjusted for those parts.
  16. #2234
    Mar 2007
    Medford
    He told me (over the phone)stage 2 is 255hp/265tq
    but thats what the paperwork states for the accessECU reflash.
    I'm going to call back monday and ask for someone who was there when they were doing this thing back in 03.
    As far as i'm concerned, the car runs flawlessly :knocks on wood:
    Peaks at 16.5lbs, idels 100% smooth, pulls hard around 3k
    But like I said, Im a class A NooB in the scoobie world.
    btw... thanks for all your help
  17. #2235
    Dec 2004
    Medford, Oregon
    Nick if your receipts for the turbo back and up pipe were before the ecu reflash, I wouldnt worry about changing anything until you want to do more up grades. At this point Id turn the focus into stopping and turning power.
