Wade,is it doing it just when the car is cold or does it do it when its warmed up too?
--if its just doing it when its cold you may look for the leak is check your evap system for leaks. check all your vacume lines at the evap canister and purge solinoids. if you have a leak on one of the lines or a sticking purge valve thats dumping uncatalized fuel vapor, in the morning when the computer is add extra fuel for cold motor and weather start the system will build alot of extra uncatalized fuel in the evap and charcoal canister. i fought what i thought was a fuel leak on one of my motor swapped cars for weeks in the morning when it was cold the thing smelled like i had a huge fuel leak, but when it warmed up the smell would dispate. i ended up figuring out that i had a cracked vacum line on my evap canister. -- if you get stuck and need a hand hunting it down just let me know, i got a ton of experience with fuel leak and smell issues working on hyundias.
LinkBack URL
About LinkBacks
