tri way projector Headlight wiring.
Results 1 to 10 of 10
This is a discussion on tri way projector Headlight wiring. within the North Western States forums, part of the Regional Discussion category; is there something funky with the factory wiring in a REX. Like maybe common positive rather than negative?. I was ...
    Dec 2002
    Covington Washington
    is there something funky with the factory wiring in a REX. Like maybe common positive rather than negative?. I was putting in my new lights and it was all whacked out. I put a meter on the factory harness and got some weird measurements. anyone have a factory wiring diagram for the headlight system for these cars?
    Registered User iv30's Avatar
    Dec 2001
    NC
    Which lights are they?
    If they are STI lights heres a wire layout
    Passenger Side
    OEM Ground blue/white - Combine with one wire from each harness
    OEM High red to 9005 wire
    OEM Low yellow/red to blue wire on H1
    Driver Side
    OEM Ground red/blue - Combine with one wire from each harness
    Dec 2002
    thats fine and dandy ..if my red/blue was gnd and not +12 like it is. I think the wrx has a common positive and they switch ground to activate/deactivate the different beams. Still searching though.
    Registered User is2scooby's Avatar
    Jun 2002
    Honolulu, HI
    My voltmeter readings were like yours, I wired my lights like IV30 and they worked fine.
    Aloha, Richard...
    Retired Moderator
    TXS Stage 4 UTEC + TMIC + JoeP
    12.75 @ 105.67mph - 1.74 60'
    Dec 2002
    They work fine as long as I don't try to make them work like they were originaly wired. there is an extra relay that keeps the lo beams on when the hi beams are turned on. that is what the problem was. I was putting source voltage to the relay rather than ground.
    Dec 2002
    SO MANY PROBLEMS.
    They are all fixed now. the REX has a common possitive headlight system. The different states are switched by switching the ground side of the filliment. I am currently working on a wiring digram in CAD and will post an image of it when I am done showing the wiring for the lights that I have and showing the function of them.
    Dec 2002
    Thumbs up
    Here we go. I now have a wiring diagram for the lights.
    Jun 2002
    Honolulu, HI
    Mahalo (thank you) - great work!
    Aloha, Richard...
    Retired Moderator
    Dec 2002
    not a problem.
    Dec 2001
    NC
    Wow nice job
