Ohio Roll Call - Page 34
Page 34 of 197 FirstFirst ... 24252627282930313233343536373839404142434484134 ... LastLast
Results 496 to 510 of 2942
This is a discussion on Ohio Roll Call within the North Central States forums, part of the Regional Discussion category; Originally posted by tubbytreats 15.9 PSI was my peak in 4th and 5th gears. The AccessPORT works really great as ...
  1. #496
    Registered User MidnightFLAT4's Avatar
    Sep 2003
    Dayton Ohio, Chicago IL
    15.9 PSI was my peak in 4th and 5th gears. The AccessPORT works really great as a digital boost gauge, and I was using it all the way back from my meeting tonight on I-675 and my eyes were glued to the greenish backlight glow of the AccessPORT.
    I think I'm going to kill myself because of this little devil!
    Your stage 2, so youll probably get over 16 eventually.
    Im noticing great values for first gear. 14.7 at about 5k.
    even with stage 1, the car still points its nose WOT in third gear. This is pretty remarkable. One guy in a truck noticed my glowing accessport. "What the hell is that ?"
    Me: "boost"
    03 MBP WRX Sedan
    STi RA gearset October 4th,STi Trans Mount
    Cobb AccessECU STG II 16.4psi. Bosal DP, Catless OEM UP, 205/55 ZR16 Futura Ultra Z's.
  3. #497
    Registered User Shibby's Avatar
    Jan 2003
    Dayton, OH
    Originally posted by MidnightFLAT4
    Got my car back (brand new limited slip), flashed 91 octane base. 15.1psi 3rd
    burned off the 92 octane, filled up with sunoco 94 and switched to STG1 93. 15.3psi, 50 degrees.
    heres the kicker, (12.5psi at 2900).
    so... who here has experience with up-pipe installs? or at least a downpipe install?
    I can offer cash, or beer.
    i did my own uppipe, and i have tools
    beer will be fine
    actually, i have STi mounts to go in as well
    perhaps we can do an install day of some sort.
    --Jason-- 2004 MT WRB WRX
    Cobb Stage 2 more goodies:
    STi SS | Blitz SUS | Samco IC Hoses | Perrin Rear Sway Bar and Endlinks | Eibach's | Steel Gray Rota Downshifts | Goodyear Eagle F1 GS-D3's | Blitz DTT-DC2 | Phatty-Ass System
    "This is my WRX. There are many others like it, but this one is mine. My WRX is my best friend. It is my life. I must master my WRX as I must master my life. Without me, my WRX is useless. Without my WRX, I am useless."
  4. #498
    Registered User tubbytreats's Avatar
    May 2003
    TurboFlat04,
    You are in luck. Shibby and I both have done our own installs, and I even made my own Tutorial thread on how to do it yourself. Check here to see it: Uppipe, Downpipe, Muffler INSTALL GUIDE!
    I'm down with helping whenever you decide to do your install. I just blew all my cash recently, so I won't be doing any parts installs however.
    2002 WRX Mods:
    AP Stage2/93, ScoobySport Up, Dp, & Muffler, SS AutoChrome TMIC, Hawker PC680T Battery, Injen CAI, ACT Stage2 Clutch, Gruppe-S 13.8lb Flywheel, Mobil1 and Redline oil, NGK BKR7EIX plugs, Goodridge SS Lines, Motul RBF600, Hawk HPS pads, 35% 3M tint, Koji Headlight Mod, SilverStar Bulbs, Blaupunkt MP3000 headunit, Infinity BassLink Sub, Kenwood KFC-1689ie speakers (6.5"F / 5.25"R), Rota Downshift (Black), Yokohama AVS ES100 (225/45/17)
  5. #499
    Registered User integratowrx's Avatar
    Aug 2003
    Ohio
    I saw your car at Wagner last week when I was getting my new radiator. They said the limited slip usually goes out when you do too many donuts........I assume they covered it under warranty right?
    Tubby, are you still using your CAI? I remember reading on the Cobb site that they have to tweak Stage 2 a little if you have an intake.
    '02 PSM WRX
    18" P1's, TBE, and Cobb Stage 2
  6. #500
    May 2003
    I'm still using my Injen CAI. I've only heard of serious problems with Cobb's stuff and the AEM intakes that are out there. Supposedly, the AEM stuff gives wildly fluctuating MAF sensor readings and cannot be tuned for with any tuning package. I KNOW Cobb already has a map that's tuned for Injen intakes, so I'm going to wait it out and see what I might be able to download in the near future.
    As of yet, I haven't experienced ANY pinging or problems with detonation even at WOT. The AccessPORT still has some learning to do with my car, but I'm very satisfied with the increased boost levels and added powerband smoothness.
    2002 WRX Mods:
  7. #501
    Aug 2003
    Ohio
    I know your ecu is still learning, but have you noticed a bit more top end power also? That's good you've had no pinging etc....
    I want my accessPORT right now!
    '02 PSM WRX
  8. #502
    Registered User Snowvert's Avatar
    Mar 2003
    ran up to kilkare after class. was cold as sht, but wasn't raining. was a few cool cars up there. a white evo running 14's.
    a cobra running 14's too. was very odd, but was fun. just too damn cold. supposed to be at least 50's on saturday... anyone want to go up there? i'm planning on it.
    03 wrx - 300whp/270wtq
    Originally posted by zoophagy
    The people that work there are, for the most part, retards. I used to work there.
  9. #503
    Registered User fatgroundhog's Avatar
    Nov 2003
    Yea, I got my AccessPort today! IntegratoWrx came by, we put stage 2 on his, had some fun, then put stage 1 on mine. Very, very nice. I'll let him tell you his thoughts (he may be crying right now since we put his back to stock).
  10. #504
    Aug 2003
    Ohio
    Yes my drive home was boring with my Stage 0. I was very impressed with Stage 2 though. As tubby said, the car just seems very smooth. A lot easier to cruise around in 1st and 2nd at lower speeds. I was getting just over 16 psi in 4th and 5th, and the top end definitely was impressive. I can't wait for mine to arrive, I'm hoping it will be here any day now. Stage 1 definitely felt considerably better also. Fatgroundhog should be getting his downpipe sometime next week and quickly moving up to stage 2.
    I'm headed to warm and sunny Florida on Saturday, so I won't be going to Kil-Kare. Saturday's are the money races for the domestics right? No imports I don't think.
    '02 PSM WRX
  11. #505
    Mar 2003
    10-1 is the bracket racing and 1-5 (till whenever) is just like the saturday we all went to. some imports, some drag, etc.
  12. #506
    Sep 2003
    Yea, that was my car. For the first 12k i beat the livin hell out of the car, till i broke second gear last year. Now i have 27k, ive been pretty much babyin it. It blew out in the rain, but Wayne said that diffs arent that common to explode like mine did.
    Yea wagner subaru is by far THE best dealer in the midwest.
    "Now, i turned my head on a few modifications I saw. I know they arent a big deal performance wise, but other dealers would ask you for 1200 bucks before you get the keys." -wayne
    He told me that abusive driving can cause the diff to go out.
    He said, "be nice to the car, they will last. Oh... and It drives like a dream." when i started the car I noticed they burned about an 8th tank probably "testing the new diff".
    I'm really glad i decided to have it worked on there versus White Allen.
    Im even more glad this happened BEFORE i got the accessport.
    03 MBP WRX Sedan
  13. #507
    Mar 2003
    white allen? pls no.
  14. #508
    Nov 2003
    Just coming in from my Stage 1 drive to work. Very nice. Ahhhh. The car should be this way from the factory. I wasn't even getting on it and you can still tell. Its just wonderful.
    I guess I could offer to prostitute my AccessPort out for a few hours at a time. I'll go back stock, let you go to whatever, drive for a little while, then you go back stock and let me have my toy back. The last part is key. You must let me have my toy back.
    I also promised to plug South Coast Subaru, the Cobb dealer I got my AccessPort through (same price). They actually may have one coming in with Integratowrx's that hasn't been claimed yet.
  15. #509
    May 2003
    Good news on the AccessPORT everyone! Sounds like we're all quite satisfied with our purchases! I'm really enjoying the extra power, but it's too wet to have any real fun with it right now.
    On a side note, what's up with this when I log in every day? I see Fatgroundhogs' name! I think we are both on the same proxy server here at the base, and somehow your login name always comes up every day when I go to ClubWRX.net, even though I'm logged in! It's really really weird.
    I can't read your PM's or get into your settings, so you don't have to worry. It's just quite odd that this is happening.
    2002 WRX Mods:
  16. #510
    Nov 2003
    Whoa, Integratowrx's does that too- he loggs on and it says "fatgoundhog" but then he gets his own PMs. Who knows???? It did kinda make me scared when I saw that though. Maybe that just means I'm cool.
