Winter Tires?
Page 1 of 5 12345 LastLast
Results 1 to 15 of 72
This is a discussion on Winter Tires? within the North Central States forums, part of the Regional Discussion category; Hi everyone! I just got my WRX at the end of April and live in northeastern Indiana. What are your ...
    Aug 2014
    Winter Tires?
    Hi everyone!
    I just got my WRX at the end of April and live in northeastern Indiana. What are your suggestions for winter tires? Should I go with a dedicated snow tire or should I get an all-season tire so I don't have to keep switching them out every Spring and Fall?
    Thanks in advance!
    Palmyra, NJ
    Lot of good winter tires out there.
    I would steer clear of No-season tires because they are pretty meh in all seasons. Indiana gets hit with some decently bad winters, so opt for a dedicated set.
    A lot of people will drop the coin on a spare set of wheels to throw the winters on so they can just swap em out themselves. Totally worth it. Plus, the two sets of tires will make the winters and summers both last longer (with normal rotation intervals) so that you don't have to buy a new set of regular tires as quickly.
    Aug 2012
    Tucson, AZ
    This. I ran on my stock 17's 205-50-17
    I believe it was a 50 profile at least
    General altimax arctics. Absolutely no complaints, night and day difference
    Hawkeye Alliance 520
    Previous cars:
    2010 Mitsubishi Lancer (sold)
    2009 WRX (sold )
    2013 Scion tC (sold)
    2008 Audi A4 (Totaled)
    Photographer/storm chaser
    https://www.facebook.com/kevinrimphoto
    IG - kevinrimcoski
    Aug 2014
    Thanks a lot for the advice. If I were to get an extra set of rims, do you guys know what the measurements I need to look for are for the WRX? I know it's 17", but much past that I'm not sure. I've seen a few different sizes. Are there any you recommend, or good places to look for them?
    What are your thoughts on Blizzak tires? It seems like a lot of people go for those.
    Contributes Nothing ShiftingLanes's Avatar
    May 2013
    Riverdale, NJ
    Quote Originally Posted by nsibanez View Post
    I run these. They are amazing. 4k miles, little to no visible wear after one of the worst winters snow wise the northeast has ever seen, amazing grip, not expensive. I was recommended these by many experienced forum members and would do the same for anyone looking. You cannot go wrong with these tires.
    http://shiftinglanes.com
    '14 DGM WRX Limited Hatch
    I'm a build thread?
    Stink-eye Mob #49
    Palmyra, NJ
    for WRX, you'd need 5x100 bolt pattern (assuming you aren't a 2015 owner). You can fit 16s as well which would make tires cheaper, and probably run better considering they'd be thinner (better in the snow).
    Popular thing is to look for used WRX wheels from older generations.
    Otherwise you'd want a +40 to +53 kind of range for the offset.
    Aug 2014
    I'm glad you brought up the older models. I was wondering if the older WRX model rims would work on my car? I have a 2014 hatchback.
    Palmyra, NJ
    Quote Originally Posted by Runnikee View Post
    Yep. Any WRX wheels (and Legacy wheels) would fit as you do indeed have the 5x100 bolt pattern. STI wheels will not fit. Common winter wheels are 02-05 WRX wheels as well as 00-2004 Legacy "Snowflake" wheels. Both are 16in, which means tires would be on the cheaper side. You can usually find a good used set without tires for as cheap as $100.
    Registered User soloz2's Avatar
    Jan 2011
    Western NY
    Yep, you can. I picked up a set of 02-04 wrx wheels and am in the process of prepping them for paint. My new snow tires arrived yesterday. General Altimax Arctic in 215/55 16.
    Sent from my GT-N5110 using Tapatalk
    Current Rides: 05 Outback XT 5MT & 14 Forester XT Premium
    Past Subies: 14 WRX hatch, 06 Legacy 2.5i SE 5MT, 98 Outback wagon
    Oct 2005
    Late Devonian
    I wouldn't run full winters in IN (grew up in OH). You really only need them if you live in terrain and have significant snow. Winter "Performance" tires are the way to go for me, as the difference on most days, when there is little to no actual snow on the roads, is quite an improvement. I get as much snow as you, and live in real mountains with a steep driveway, and am still kicking myself for getting "snow tires" this time out.
    I liked the Pirelli Winter Sottozero Serie II quite a bit. Looking on tirerack (who has a "winter performance" category you can search) now though, with the rebate the 2 pound difference in weight I'd like the pricing on the Michelin Primacy Alpin PA3 quite a bit. I don't recall them being in the same ballpark when I got mine.
    Aug 2014
    I was actually just on tire rack today and saw this category and was going to ask about it. What's the difference between snow and winter performance I wonder? Last winter was the second worst winter on record here and we had over 70" of snow from December through April. Do you think the "winter performance" could handle that if we got it again?
    Also, I see a lot of you are running sizes other than the 235/45/17 that comes on the WRX. What sizes can I run? Why would I want to change tire size from the size that comes on the car from the factory?
    Thanks again everyone! I'm loving all the information you're sharing.
    Jan 2011
    Western NY
    A narrower tire will dig through deep snow better.
    If you get lots of snow a performance snow tire won't be as good as a ice/snow tire.
    I put General Altimax Arctic on my wife's FXT last season and they were pretty good overall. Great in snow and not too much flex or squirm on dry. They also seemed to wear quite well.
    Lots of folks go with a 16" setup for winter. The tires are cheaper and you don't loose too much in handling. I went this route. And have some 215/55 generals here ready to be mounted after I finish painting my wheels.
    I believe a 205/50 will work, but I'd check on the individual tire you are looking at the stock wheel might be a bit on the wide side for it.
    Aug 2014
    Quote Originally Posted by soloz2 View Post
    I appreciate the information! So if I go with the Arctics and we have a winter that doesn't get any snow, or rarely snows (you really never know), they'll hold up all right?
    Oct 2005
    Late Devonian
    They aren't a huge compromise and will do fine in crappy conditions. At the end of the day, a real snow tire like they are talking about (and what I have now) will get you up or down a steeper hill than a winter performance tire and will be more comforting in a really bad storm. These will pull you through all kinds of **** though just fine though. Subarus drive like kittens in the snow anyway. They are quite a bit different on dry and wet roads though - night and day IMO. So it just depends which type of day you want to plan for. IMO winter performance are considerably the best option for a performance AWD car unless you live on steep stuff that also has deep snow regularly. If it is only one or the other...?
    Aug 2014
    I live in northern Indiana, so steep hills aren't an issue. I'd say it's dry or wet roads here more than snowy in the winter. When we get snow, it tends to be significant though. Last year was a mess. I just want to know what tire and type of tire will cover my bases the best. Most of the time there is little to no snow, but I also don't want to be stuck or spinning when we get one of our usual four or five significant snows.
