Winter Tires? - Page 2
Page 2 of 5 FirstFirst 12345 LastLast
Results 16 to 30 of 72
This is a discussion on Winter Tires? within the North Central States forums, part of the Regional Discussion category; If they will allow you on the roads in IN, you can get down them. The other guys will have ...
    Oct 2005
    Late Devonian
    If they will allow you on the roads in IN, you can get down them. The other guys will have more fun on those few days though. Hell I grew up in Cleveland with a RWD estate wagon and it would spin up some tires.... Ever since trying some, I've felt the WRX communities' adherence to full winters has something to do with the "rally heritage" thing or something.
    Aug 2014
    Haha, could be! I'll look into the winter performance tires. That seem to be more expensive from what I've seen.
    I've been driving a RWD Dodge Dakota for the past twelve years and have never been stuck in it. I've never had a 4WD so I'm looking forward to some bad weather haha!
    mrd
    mrd is offline
    Registered User mrd's Avatar
    Nov 2010
    Livermore,CA
    I'd say for wrx 16x7 wheels and Michelin pilot alpin pa3 205/60x16 would do the job. With this set of winter tires you will be able to hold on your performance but no snow or rain would slow you down. Keep in mind that you will use them at least 3 years and same time for summer tires. Its around 30k miles per set. I am able to use my winter set one more season, but summer tires had to go after 3 years and they will go on my BRZ this winter, but for STi I will have to buy new winter set tires and wheels.
  6. #19
    Aug 2014
    Quote Originally Posted by mrd View Post
    I'm going to be using my stock 17" rims, so the 16x7 wheels aren't an option for me.
  7. #20
    mrd
    mrd is offline
    Nov 2010
    Livermore,CA
    Then go with Mich pilot alpine pa3 205/55x17 they will rise your car for 7mm, but this is not a big deal.
    You can say that I'm Michelin fan.
  8. #21
    Aug 2014
    I've seen people talking about running different tire sizes and didn't know what the difference was, the advantage of different sizes, or what sizes I could run?
  9. #22
    Aug 2012
    Tucson, AZ
    The thinner the tire the betyer it cuts into the snow. I used general altimax 205 on a 17. Cheap and amazing wet and dry traction. Absolutely amazing in blizzatds
    Hawkeye Alliance 520
    Previous cars:
    2010 Mitsubishi Lancer (sold)
    2009 WRX (sold )
    2013 Scion tC (sold)
    2008 Audi A4 (Totaled)
    Photographer/storm chaser
    https://www.facebook.com/kevinrimphoto
    IG - kevin rimcoski
  10. #23
    Aug 2014
    205/55? What do the different numbers mean? Why did you choose that over the stock size?
  11. #24
    Oct 2005
    Late Devonian
    Tire sizes are all messed up. The first is the width (205 mm) and the second is the profile as a proportion of that. So the second isn't an actual measurement or anything you can compare across.
    Just look at the overall circumference for the particular tire and find the closest one.
  12. #25
    mrd
    mrd is offline
    Nov 2010
    Livermore,CA
    205 width
    55% is geometrical hight of tire, so for 205mm height is 205mm*55%=112.75mm
    now geometrical radius is: (17"*25.4/2)mm+205mm*0.55=328.65mm
    stock tire radius is:321.65mm and then geometrical difference is 7mm.
    There is a dynamical coefficient that is multiplied with geometrical height to determine real clearance of the vehicle. Therefore the difference in height is not 7mm but less.
    There are many web sites with tire dimension calculators.
  13. #26
    Aug 2014
    205 width
    Haha, wow! I'll probably stay with stock size to avoid any possibilities of making a bad guess on what size I want.
  14. #27
    mrd
    mrd is offline
    Nov 2010
    Livermore,CA
    No guesses this is pure geometry.
  15. #28
    Aug 2014
    I guess I'm just confused because I've always thought a wider tire (more surface area) would give you better grip in all conditions.
  16. #29
    Aug 2012
    Tucson, AZ
    Quote Originally Posted by Runnikee View Post
    Except snow
    Think of skis or snowboard. You use the edges to carve through the snow. Same effect
    Previous cars:
    2009 WRX (sold )
    IG - kevin rimcoski
  17. #30
    Aug 2012
    Tucson, AZ
    And I got my alternate size from tire rack when they had it
    Previous cars:
    2009 WRX (sold )
    IG - kevin rimcoski
