OHIO: AUTOCROSS/DRAGRACE EVENT MAY 25-26 NORWALK,OHIO
Results 1 to 3 of 3
This is a discussion on OHIO: AUTOCROSS/DRAGRACE EVENT MAY 25-26 NORWALK,OHIO within the North Central States forums, part of the Regional Discussion category; 6th Annual Buschur Racing Sport Compact Nationals-May 25 & 26, 2013 Saturday, May 25th, 2013. 9am to 5 pm. Buschur ...
    Hammerdown Mod of Thunder josnroh's Avatar
    Feb 2003
    oHIo
    Saturday, May 25th, 2013. 9am to 5 pm. Buschur Racing, Inc., Wakeman, Ohio
    DYNO DAY!!!
    $50 for three pulls.
    AWD, FWD, RWD cars welcome. 9am to 5 pm.
    Sunday, May 26th, 2013. Summit Motorsports Park, Norwalk Ohio.
    -Gates open 8 am to 5 pm
    -Car and driver autocross only, $35
    -Max Effort autocross/drag, $65.
    -Spectator, $15
    -Active duty and reserve military free with ID
    -12 and under children free
    -MANDATORY drivers meeting for MAX EFFORT AND AUTOCROSS at 9:30 am, course walk immediately after drivers meeting.
    CLASSES:
    MAX EFFORT:
    This class puts the best car/driver combination together to show what both are capable of! You will get at least 4 autocross passes and 3 drag runs. Your lowest time from each of those events will be added together to place you in the final standings.
    Any car competing in FME or AME must run the same tire (140 and up tread wear) for the autocross and the drag races. NO tire changes permitted. Your best ET from your autocross runs will be added to your best 1/4 mile ET and the total ET from the two will place you in the class. Lowest combined time wins! The Max Effort group will be split into their two groups. The first group will run all their autocross runs and immediately after finishing will proceed to the staging lanes for their 3 drag passes. Upon completion of the second groups autocross passes they will proceed to the staging lanes for their three passes.
    FME Street tire-Sponsored by Buschur Racing. This will be for any FWD vehicle. Tire must have a tread wear rating of 140 or higher.
    AME Street tire-Sponsored by Buschur Racing. This will be for any AWD or RWD vehicle. Tire must have a tread wear rating of 140 or higher.
    FOCUS ST-Sponsored by Buschur Racing. This will be for any Focus ST or if you want, ANY Focus you own. Only rule is tread wear has to be 140 or higher.
    AUTOCROSS:
    FA-Autocross only- This will be for any FWD vehicle. No other rules.
    AA-Autocross only-This will be for any AWD or RWD vehicle. No other rules.
    DRAG RACES
    QUICK 16
    -Heads-up. Pro Tree. Anything goes with the exception of full tube chassis RWD vehicles.
    -Three qualifiers. Times to be announced.
    IDRC TRUE STREET TURBO RWD/AWD CLASS
    A minimum class qualifying time of 13.99 must be met to make the qualifying field.
    .400 Pro-Tree
    Sportsman ladder
    Quickest elapsed time from the previous round will have lane choice for the following round.
    16 car field maximum, if you fail to make the field you can move to the Bracket Classes or run Time Trials.
    The racer on the tech card for the vehicle must also be the driver. Additional drivers will pay full race entry fee and
    must notify officials that there will be two drivers. The driver that qualifies vehicle must
    also be the driver in elimination rounds.
    True Street Class car are required to have: Headlights, signals, driver and front passenger windows, factory glass, dash board, 2 front seats, door panels, air-to-air intercoolers only, full exhaust with muffler exiting the rear of the car, no more than TWO power adders (i.e. supercharger/nitrous or turbo charger/nitrous), transmission must match manufacture of engine. Standard transmission must retain factory H-pattern.
    D.O.T. radial tires only. No skinny front tires. Metric-specified tires may not exceed a section designation of 315. All other
    tires must measure less than 10.5-inches in tread width, not in section width. Maximum
    tire height is 28 inches. No slicks allowed. No wheelie bars allowed.
    Engines are not to exceed the following displacements based on the engine’s
    number of cylinders:
    4 cylinders less than 2850cc
    5 cylinders less than 3563cc
    6 cylinders less than 4275cc
    8 cylinders less than 5700cc
    Racers wishing to challenge the displacement of another competitor’s engine will
    post a $250 protest fee. The IDRC will conduct a P&G test to determine the displacement
    of the engine. If the engine exceeds the maximum displacement allowed, the racer will be
    barred from competition at that event and all event points will be forfeited. The protest
    fee will then be returned to the racer filing the protest. If the racer’s engine is of a legal
    displacement, the protest fee will be kept by the IDRC.
    AWD/RWD
    -AWD/RWD vehicles only. No tube chassis vehicles.
    -Pro-tree, heads up class. 16 car field with qualifiers being run at 9:30 am, 10:30 am and noon. Sportsman ladder.
    FWD
    -FWD vehicles only. No tube chassis vehicles. 67mm maximum turbo size.
    BRACKET ONE
    -Handicapped start. Full tree. 0-12.99 ET.
    BRACKET TWO
    -Handicapped start. Full tree. 13.00 and slower ET.
    TIME TRIALS
    This is open to ANY vehicle that wants to just make time runs. No awards, no trophies, no payouts. Just some fun runs as time permits throughout the entire day. You MUST purchase a tech card at the front gate.
    JOE/Flyin' Under the Radar
    2015 Buckeye Boxer WRX
    2003 Hammerdown Wagon WRX(sold)
    1983 GL-10 Wagon (RIP)
    Sometimes you get the best light from a burning bridge.
    http://badges.fuelly.com/images/sig-us/282947.png
    Feb 2003
    oHIo
    The weather for this weekend is looking good.Sunny and mid sixities.
    Feb 2003
    oHIo
    Although the Hammerdown Wagon has retired from competition,I will be there as a spectator.I'll be sitting at the top of the green section grandstands.
