did you go to autozone..if not go there
This is a discussion on check engine light within the New Member Hangout forums, part of the Community - Meet other Enthusiasts category; well i got the light checked to day and it didn't give a code it said fail. what's up with ...
well i got the light checked to day and it didn't give a code it said fail. what's up with that?
05 STI![]()
Speed Comes At A Price...How Fast Can You Afford To Go?
yeah that's where i went. could it have something to do with hitting 130?
Go back. It should give the code.
-Brian
Twisty Monster - 335 ft/lb of torque @ 3600 rpm on a stock turbo. Is that possible? Yes it is.
It sounds like they either had a bad connection, or didn't use the scanner correctly.
go back, sounds like someone screwed up
--Chris
04 WRX wagon - 304whp Mods - SOLD
2008 DGM Impreza 2.5i sedan - STi Grille, GTspec cf lip, CTspec cf trunk chrome cover, Perrin shorty antennae
LISC #3
www.longislandsubaruclub.com
I think every suby dude or girl should invest in this tool , I have one and its fantastic. great great price.http://www.autotestsys.com/Merchant2...tegory_Code=ST
I have the easy-read 2000 for home use, great tool. I have the Snap-On unit at work. Really nice if you want live data, but a little pricey.Originally Posted by tekfoc
true , I have the xray 35000 scans obd I and obd II . good way to make money on the side. good way test your car before you get inspection done. does complete readiness test so atleast you know your ecu is reading ready, good for people that forgot that they reset there ecu .Originally Posted by Trainrex
it was my egr sensor. how can i make that one stop coming up.
it's the one that's at the rear of my downpipe right? don't i have to do something to fool the computer into thinking that it's got cat's too thoug?
What exactly was the code that was pulled?Originally Posted by jknakes
um....he just told me that it was the exhause gas regulator and then cleared it out. i'm sure it'll pop up again though.
My check engine light kept going on back when I first got me WRX alittle over a year ago. Just disconncect the negative off the battery, hit the brake 5 times and then put it back on. Should make light go off if its bothering you that much. Then take it to a shop and have them fix it.
It's all about rally racing, nothing more.
On second thought maybe its all about Rally Racing and Auto-X
'06 Steel Gray WRX (Stock)
