Acronyms?
Results 1 to 8 of 8
This is a discussion on Acronyms? within the New Member Hangout forums, part of the Community - Meet other Enthusiasts category; So i know what the majority of acronyms mean but lost on a few such as FMIC and FTW i ...
    Registered User Daddy_WRX's Avatar
    Jul 2007
    Colorado
    Acronyms?
    such as FMIC and FTW i can't think of the others...help!
    Registered User TheMainFrame's Avatar
    Dec 2005
    Houston, TX
    Quote Originally Posted by Daddy_WRX View Post
    FMIC = Front Mounted Inter-Cooler
    FTW = For The Win
    If you need anymore just post em up
    Bugeye Mafia #125 - And Proud Of It!
    Nov 2005
    Central Florida
    All We'll Drive
    DIFFERENT STROKES
    POST WH0RE KING
    Nov 2005
    Central Florida
    Quote Originally Posted by YBNormal07 View Post
    If you have any to add, please post them in a reply and I'll add it to the list and delete your reply. However, do not post asking about internet terms/slang/acronyms as you simply need to google those to find your answers.
    NOTE: This thread is subject to regular pruning.
    Acronyms & Basic Terminology
    • 4EAT – Four Speed Electronic Automatic Transmission
    • 5MT – Five Speed Manual Transmission
    • 5EAT – Five Speed Electronic Automatic Transmission (includes Sportshift)
    • 6MT – Six Speed Manual Transmission
    • ABS – Anti-lock Braking System
    • AFR (or A/F) - Air to Fuel Ratio
    • ALK - Anti Lift Kit
    • ALS: Anti Lag System (EM trick to keep the turbo spooled when off the throttle)
    • AT – Automatic Transmission
    • ATF – Automatic Transmission Fluid
    • AutoX – Autocross
    • AVCS – Active Valve Control Sysem
    • AVLS – Active Valve Lift System
    • AWD – All Wheel Drive
    • AWHP - All Wheel Horse Power
    • BBK - Big Brake Kit
    • BHP – Brake HorsePower (measured BEFORE transmission)
    • BOV – Blow Off Valve
    • BPV - By-Pass Valve
    • CAI – Cold Air Intake
    • Cat – Catalytic Convertor
    • Catback -- Catback (after the Catalytic Converter) exhaust section
    • CBE = Cat Back Exhaust
    • CEL – Check Engine Light
    • CF – Carbon Fiber
    • Cf -- drag coefficient or coefficient of drag (airflow resistance)
    • CO2 – Carbon Dioxide
    • Diff – Differential
    • DP -- Down Pipe
    • DC -- Double Clutch
    • DCCD -- Driver Controlled Center Differential
    • DOHC – Dual Overhead Camshaft
    • DRL = Daytime Running Lights
    • EBC – Electonic Boost Controller
    • ECT - Electronically Controlled Transmission
    • ECU – Electronic Control Unit (engine control unit)
    • EFI – Electronic Fuel Injection
    • EG – Subaru 6-cylinder engines (up through mid to late 90’s)
    • EG33 – Subaru 3.3 litre 6-cylinder engine code (SVX)
    • EGT - Exhaust Gas Temperature
    • EJ – Subaru 4-cylinder engines (early 90’s and newer)
    • EJ20 – Subaru 2.0 litre 4-cylinder engine code
    • EJ205 – Subaru 2.0 litre turbo engine (US WRX)
    • EJ22 – Subaru 2.2 litre 4-cylinder engine code
    • EJ25 – Subaru 2.5 litre 4-cylinder engine code
    • EJ255 – Subaru 2.5 litre turbo engine (US Forester XT, Baja Turbo)
    • EJ257 – Subaru 2.5 litre turbo engine (US WRX STi)
    • EZ – Subaru 6-cylinder engines (post EG series H6 engines)
    • EZ30R – Subaru 3.0 litre 6-cylinder engine code (BL/BP Legacy and new Outback)
    • EMS = Engine Management System
    • FDR - Final Drive Ratio
    • FMIC – Front Mount Intercooler
    • FWD – Front Wheel Drive
    • FSB -- Front Sway Bar
    • H4 – Horizontally Opposed 4 cylinder (boxer)
    • H6 – Horizontally Opposed 6 cylinder
    • HF - High Flow (usually used in conjunction with a catalytic converter)
    • HID – High Intensity Discharge (headlights)
    • HT-- Heal and Toe
    • IC -- Intercooler
    • JDM – Japanese Domestic Market
    • LHD = Left Hand Drive
    • LSD – Limited Slip Differential
    • MAF or MAS – Mass Air-Flow Sensor
    • MAP – Manifold Absolute Pressure Sensor
    • MBC – Manual Boost Controller
    • MIL – Malfunction Indicator Lamp (CEL)
    • MT – Manual Transmission
    • MY – Model Year
    • NOS - Nitrous Oxide
    • OBD - On Board Diagnostics
    • OE – Original Equipment
    • OEM – Original Equipment Manufacturer
    • Pinks --certain STI parts... springs, swaybars, injectors, timing belts. Due to their color.
    • Pot -- (ie. 4-pot brake) pistons on caliper.
    • P&P -- port and polish of cylinder heads to improve airflow.
    • PPG -- Pfitzner Performance Gearbox
    • RallyX – Rallycross
    • RHD = Right Hand Drive
    • RPM - Revolutions Per Minute
    • RSB -- Rear Sway Bar
    • RWD – Rear Wheel Drive
    • SOA – Subaru Of America
    • SOHC – Single Overhead Camshaft
    • SPT = Subaru Performance Tuning
    • SWRT = Subaru World Rally Team
    • STi (pre-06) / STI = Subaru Technica International
    • TMIC – Top Mount Intercooler
    • TBE -- Turbo Back Exhaust
    • TR - Tuner Ready (aka '06 WRX TR)
    • TSB - Technical Service Bulletin
    • TT – Twin Turbo
    • UDP – Under Drive Pulley
    • UP -- Up Pipe
    • USDM -- United States Domestic Market
    • VDC – Vehicle Dynamic Control
    • VIN – Vehicle Identification Number
    • VTD – Variable Torque Distibution
    • WHP – Wheel HorsePower
    • WOT – Wide Open Throttle
    • WRC = World Rally Championship (competiton or WRC Spec cars)
    Impreza Bodies:
    • GF = 5-door Impreza body
    • GG = Impreza Wagon
    • GM = 2-door (old gen) Impreza body
    • GC = 4-door (old gen) Impreza body
    • 0 = 1.6L (not certain about this one)
    • 2 = 1.8L
    • 4 = 2.2L
    • 6 = 2.5L
    • 8 = 2.0L
    • GD = New Gen Bodies
    Thanks to:
    Uncle Meat of the Cobb Tuning WRXForum.com, LegacyGT Forum, XimportnWRX, MidKnight, Max, Jhokur, anukaoen, nofear6235
    Quote Originally Posted by Subie do View Post
    Definitely a good thread but I didn't see anything about the STi Version(s).
    I know from time to time people talk about doing ver. 7 engine swaps and adding ver. 5 wings. Now you can look like you know what their talking about.
    GC chassis 1992-2000
    STI Version(S), year, and chassis code(s):
    I: 1992-1994 GC8A/B
    II: 1995 GC8C
    III:1996 GC8D
    IV: 1997 GC8E
    V: 1998 GC8F
    VI: 1999 GC8G
    *all GC body style*
    New GD chassis 2001-now:
    Japan:
    REV:
    A 2001
    B 2002
    C 2003
    D 2004
    E 2005
    F 2006
    G 2007
    In USA that would be:
    VII 2002-2003
    VIII 2004-2005
    IX 2006-
    I'm pretty sure that's how it goes. Mods or anyone else jump in if I miss anything.
    Quote Originally Posted by ride5000 View Post
    wga - wastegate actuator
    ewg - external wastegate
    iwg - internal wastegate
    egp or egbp - exhaust gas pressure or exhaust gas back pressure
    mrp - manifold relative pressure
    atdc - after top dead center (relative to piston location)
    btdc - before top dead center (relative to piston location)
    a/r - area/radius ratio
    trim - (exducer diameter)^2 * 100 / (inducer diameter)^2
    mbt - minimum best timing
    lambda - relative richness, 1 = stoich
    All We'll Drive
    DIFFERENT STROKES
    POST WH0RE KING
    Dec 2005
    Houston, TX
    Darn! ive never seen that thread but thats nice!
    Nov 2005
    Central Florida
    Quote Originally Posted by TheMainFrame View Post
    its in the new member hangout
    All We'll Drive
    DIFFERENT STROKES
    POST WH0RE KING
    Dec 2005
    Houston, TX
    Quote Originally Posted by rr1911 View Post
    Props!
    Administrator ...De Rerum Natura TheJ's Avatar
    Bro do you even live in the Dirty South
    If you click and book mark the links in my sig you will have this.
    -The J 𒂼𒄄
    "Driving most supercars is like trying to manhandle a cow up a back staircase. . . This is like smearing honey into Keira Knightly" -JC
