Uppipe question for a noob
Results 1 to 15 of 15
This is a discussion on Uppipe question for a noob within the New Member Hangout forums, part of the Community - Meet other Enthusiasts category; Hey all..great site! I just picked up an '03 WRX wagon. Car is stock, except for a SPT cat back, ...
    Registered User pweizman's Avatar
    'Nati, Ohio
    Arrow Uppipe question for a noob
    Car is stock, except for a SPT cat back, and subaru short shifter.
    I was thinking of adding an uppipe. It seems like the STI OEM is the best, cleanest option. If I get one of these...what do I do with the EGT?
    Aftermarket ones seem to come with a EGT fooler...or something?
    Also...do you just pick up the OEM STI uppipe from the dealer? Are all years compatible with my '03?
    Thanks,
    Patrick
    Registered User bkotzman00's Avatar
    Apr 2006
    York, PA
    cheaper option is get an wrx oem used and gut it or find one already gutted and plug the egt with a screw and reinstall cost about $50 if you gut yourself (what I did)
    04 WRX Java Black
    Mustang Dyno 218 awhp 216 awtq
    1978 Honda CB400Tll
    yea you know its modified
    1974 Honda CB750 Bobber
    still in the works
    'Nati, Ohio
    Do you just leave the EGT sensor unplugged?
    Doesn't that throw a CEL?
    Later,
    Patrick
    Registered User cheeseybacon's Avatar
    Jul 2004
    Chambersburg, PA
    If you decide to use a gutted stock WRX uppipe or an aftermarket uppipe with an EGT bung, simply plug the bung hole with a bolt. In either case, whether it's an STI uppipe or gutted WRX / aftermarket pipe, you're going to want to disconnect the EGT sensor. Follow the wire running from the EGT sensor until you come to a wiring harness connector where you can disconnect the sensor. Stick a 1/2-watt 2.2k ohm resistor (available at RadioShack for about $1) into the wiring harness connector where the EGT sensor was previously connected. The resistor will keep you from receiving any uppipe-related CELs.
    'Nati, Ohio
    Quote Originally Posted by cheeseybacon
    AH....
    Does anyone make a nice, plug in "fooler"?
    Later,
    Patrick
    Registered User DTR rex's Avatar
    Jun 2003
    Chi-town, IL
    +1.
    Cheapest and easiest way to go about it.
    Just call me Clark Kent
    Offical Body Guard for the Bugeye Mafia.
    Sep 2006
    Highlands Ranch, CO
    Quote Originally Posted by pweizman
    AH....
    Later,
    Patrick
    didn't you read? He said it was called a 2-watt 2.2k ohm resistor. (available at RadioShack for about $1) what more do you need. it plugs right in to the same spot, and is FAR cheaper than buying an "EGT Simulator" online for $15.00+S&H. Plus the "simulators" don't exactly have a clean record. Lots of people with bad ones.
    -Robert R.
    Touge Speed...
    'Nati, Ohio
    Quote Originally Posted by Z_Spool
    I did read. Specifically what I wondered was if there was a very clean way to do it.
    I know shoving a resistor into the plug will work, but long term...will it fall out, will I have to tape it up...etc....
    Maybe the best route is to hack the plug off the EGT sensor itself, and solder in the resistor?
    Just doing some bench research...no disrespect intended...
    Patrick
    RSX-S
    Sold: '03 WRX Wagon (bugeyes rock!)
    Apr 2006
    York, PA
    i would avoid cutting connectors you never know you might need to go stock again, but some people use like silicone caulking and just cake the resistor and plug so no water gets in there
    04 WRX Java Black
    1978 Honda CB400Tll
    still in the works
    Jul 2004
    Chambersburg, PA
    Patrick
    Honestly, it's not rocket science. How much cleaner do you want?!?
    'Nati, Ohio
    Thanks Man...my bad.
    Patrick
    RSX-S
    Registered User SuckTheBruce's Avatar
    Jun 2006
    Milwaukee area
    Patrick
    I watched my tuner put the resistor in and then put some heat resistant electrical tape around it so it wouldn't fall out. It definately doesn't look "dirty".
    I drive a WRX and work for Harley-Davidson .
    Blobeye Syndicate #42
    GO CUBBIES!!!
    '05 CGM WRX
    Quote Originally Posted by powder View Post
    I love chowder. Cuz it rhymes with powder.
    Nov 2005
    Central Florida
    is the same thing for the STi ?
    Jun 2006
    Milwaukee area
    Quote Originally Posted by rr1911
    As far as I know, but the STi doesn't have a cat in the up-pipe, so you don't need to gut/replace the up-pipe.
    GO CUBBIES!!!
    '05 CGM WRX
    Jul 2004
    Chambersburg, PA
    Quote Originally Posted by SuckTheBruce
    Correct. All STIs come with catless uppipes, thus it is pointless to install a new uppipe or perform a resisitor mod. The only time an uppipe upgrade is necessary on the STI is when a very large turbo is involved that needs an increased pipe diameter and/or you are making a switch to a twinscroll turbo and/or external wastegate setup. The vast majority of the time, the stock uppipe is more than adequate for the power levels that the typical STI owner will be running at.
