Why doesn't your friend get his ass on here and post if he's so concerned?
And, well, here are some links I suggest you check out:
The "Good first mods" sticky
And here's great coverage of FAQs from NASIOC.
This is a discussion on Newb with mod questions within the New Member Hangout forums, part of the Community - Meet other Enthusiasts category; Hey Guys, A friend of mine just bought an 02' WRX and it came with a bunch of mods already ...
Hey Guys,
A friend of mine just bought an 02' WRX and it came with a bunch of mods already on it. Because I'm such a car nut, he came to me to ask what I thought about all the mods. I told him I didn't know much about WRX's, but I would do some research and find out for him.
This is his list of mods right now:
Perrin Intake, APS Top Mount Intercooler, APS BOV, HKS Grounding System, Perrin Catch Can, Turbo Back exhaust(I think its Tanabe Racing Medalion) with the real wide opening right at the turbo, APEXi AVC Type-R, and GReddy Turbo Timer.
Now some questions. They are numbered so when responding please reference the question number. Thanks.
1. Are these good mods? It seems to me like they are, however I have read bad things about the BOV's and EBC's on WRX's.
2. What type of power do you think he's putting to the wheels right now at about 13.5-14 psi?
3. He is already thinking about getting the COBB Stage 1 programmer, but what else should he consider doing? The car seems to be in pretty good condition.
4. The clutch feels real heavy, so it may have an aftermarket clutch. However, first gear grinds almost everytime you put it in gear. Do the 02's usually have problems with transmissions?
Thanks for all the help you can give me guys. I really want to help him with this car so I have a friend that can actually keep up with me.
Black 2005 Dodge SRT-4
265whp 336wtq @20psi Stock Turbo
276whp 343wtq @22psi Stock Turbo
~Heather | ScoobyDMCtt | Official Bodyguard # 2 for the Bugeye Mafia
Finally Stage II!
Because he has no idea how cars work, or how to modify them on his own. All he knows is that he wants a fast car.Originally Posted by Speedette
I actually already looked at those and he has most of the mods listed. I forgot to mention he has an UPP too. So.....You guys have been real helpful so farOriginally Posted by Speedette
I called Cobb and found that his best bet would be a Pro Tune at a certified Cobb Dealer. So, thanks again for the lack of help so far. I thought the SRT forums were harsh, but you guys are just plain rude and ignorant. Keep up the good work.
#1 While the 02 ecu's can be run with a BC it is not recommended. Your friend runs the risk of PT/FB with a BC which is not a good thing at all. As for the BOV it's pointless and most intakes will make the car run lean.
#2 Depending on what dyno I wouldnt say anymore then 170. All the mods you listed will not work well with each other unless properly tuned.....which the car isnt at this point.
#3 If he has a TBE then he would flash to stage 2. As far as easy mods your friend should put the stock air system back in and the stock BPV. Neither of these systems are stressed by the stock turbo. Then your friend could run stg2, but with the larger TMIC it might be a tad bit laggy. I would also sell the Turbo Timer and fine a good uppipe. A catless UP will increase spool by about 500 rpms. The TT is pointless as these turbos are cooled by oil and coolant and dont need to idle to cool down.
#4 For the most part it is well accepted that wrx's tranny's are not the strongest. The heavy clutch would actually hurt the gears much faster then the stock clutch. 02-early 03 gears are actually the weakest gears in a wrx. If 1st is grinding try to swap out tranny fluid to a good synthetic.
#5 It appears that this car was setup for a larger turbo and someone retuned it back to semi stock to unload it. Either that or someone was just plain stupid with a credit card and didnt research any mods. Either way there is a good chance this car was beat on pretty good. Tell your friend good luck and do some research. And yes I know you didnt have a #5 listed.
Geez guy....give it time....one person responded to your post who wasnt all that helpful. Doesnt mean that this forum sucks and that we are rude and ignorant (althrough if you stay around for more then a night I wouldnt argue that some of us arent).Originally Posted by Bflaker
Not everyone is going to type in this thread and answer the same questions that have been asked several times before. Some will through so no use in pissing out your camp fire before everyone gets a chance to make smores.
I know. It was just that the first two posts right off the bat set a bad example. I appreciate you helping though. I think he's going to leave all the stuff on though and take it and get it tuned on a dyno at a certified Cobb Dealer. That way everything works in harmony. I'm pretty sure we will be taking the APEXi AVC off though. I'll try the trans fluid change. We have a flush machine at my garage that can suck out the old and replace it with new fluid all at once. Its pretty slick. What is your opinion about getting the car tuned with all the mods on it that he has. What kind of power do you think he will be making then?Originally Posted by 302@12psi
With a good protune and depending on what kind of a dyno anywhere from 220-240 at the wheels. I would lose the BOV, TT, EBC. The intake can be tuned for as can the larger TMIC. The larger TMIC isnt really needed on the stock turbo, and will probaly make the car lag more then it'll help, but the protuner shoudl be able to fix some/most of it. Good luck
Cool. Thanks again for the help.Originally Posted by 302@12psi
And to the SRT-4 owner: I didn't even look at your sig. Sorry. I thought you were a WRX owner that was being sarcastic. Sorry for the confusion brother.
+1000000Originally Posted by 302@12psi
And I got your thread going, didn't I?And I still think you should have your friend post on here too so he can do some of his own looking around. That's how we all learned.
Finally Stage II!
Didnt you make some thread about a snow meet and get banned there???Originally Posted by Death To Ricers
It's not a joke at all....I know that the wrx is the best 4 door turbo car ever made......period.Originally Posted by Death To Ricers
it was a joke.
