The main thing to look at when picking a filter is the bypass pressure. MANY oil filters don't have the same bypass pressure as the OEM filter.. does that make a noticeable difference? I doubt it, but you may end up with more oil bypassing the filter than what the engine was designed for, and that could mean dirtier oil over a period of time. For what it's worth, WIX filters do have the correct bypass pressure.. and when compared to most other brands the internal construction and filtration level is superior (internally WIX and NAPA Gold filters are identical as far as I know). WIX is what I run on all of my vehicles.
As far as oil, turbo charged engines kind of need synthetic. You
could run conventional (I wouldn't), but turbos are hard on oil and I would expect it to shear rather quickly. If it's a stock block (OEM clearances), then I would run the weight which is recommended in the owner's manual (typically 5w-30). If you are going to be driving the car hard, and/or live in an unusually hot climate I would run 5w-40 (or 10w-40). When it comes to the brand you're not going to notice a ton of difference (you can compare used oil analysis data on
bobistheoilguy.com). There have been several reports of Mobil 1 5w-30 synthetic performing poorly in turbo Subaru engines (abnormally high shear over a relatively short period of time.. other weights of the same brand don't have this problem), so I would avoid that. Also, the regular line of Royal Purple oil has some issues with it (frothing being one) which I would also avoid. Other than that it's mostly up to personal preference. The vast majority of brand name synthetics will have similar performance and should be plenty sufficient for normal driving. As for myself, I run Castrol Edge 5w-30 in three of our vehicles, and Motul 300v Chrono 10w-40 in my modified WRX. I have also used Amsoil in the past with good results.
