wheels for winter tires - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 28 of 28
This is a discussion on wheels for winter tires within the New Member Hangout forums, part of the Community - Meet other Enthusiasts category; Yes, i will keep the stocks as my winters and just go all out on my summers. But keeping the ...
    Registered User ajaxthecleaner25's Avatar
    May 2014
    Freehold
    Yes, i will keep the stocks as my winters and just go all out on my summers. But keeping the domestic boss is always a must.
    2015 Limited WRX on order . . . JUST GET HERE ALREADY!
    May 2014
    Freehold
    Where did you order them through?
    Registered User Raven Logics's Avatar
    Dec 2007
    Canada
    Quote Originally Posted by ajaxthecleaner25 View Post
    I bought them privately. Some guy ordered a set from Tire Rack, imported them into Canada, put them on his STI while waiting for a '15 WRX, and then decided he wanted a set of BBS wheels instead. I paid less than half his invoice price and I don't think he was exaggerating when he said they had seen about 150 miles of use - not a mark on them and the new tire nubs hadn't even worn off
  6. #19
    May 2014
    Freehold
    WOW, lucky you. nice pic up.
  7. #20
    Registered User 2014WRX's Avatar
    Feb 2014
    Quote Originally Posted by Oilypablo View Post
    Don't overlook Dunlop Winter Maxx. Amazing tire in snow good on ice.
    ^ This. Loved mine this winter.
    2014 WRB WRX
  8. #21
    May 2014
    Hampden Maine
    I am narrowing my decision on wheels/tires, have some ? Teach me. Wheel offset. Stock is ? on 2015 WRX limited should I change to different offset? why? what is best
    Also, some wheels are cast, some machined, some are lighter (18 lbs) some heavier (22, 24 lbs etc). The roads I travel in Maine are rough and potholed, so I need ones that are durable if possible. Am looking at Sparco Assetto Gara either Gold painted or Black painted from Tire Rack. Thanks for opinions
    Mike
  9. #22
    Dec 2007
    Canada
    Quote Originally Posted by guzziman View Post
    Mike
    Stock wheels are 17x8 ET+55, and weight around 24lbs. Bolt pattern is 5x114.3.
    Here is what I "think":
    Assume that you go for an 8" wide rim like stock - ET+45 will bring the wheel out by 1cm and +65 will take them in by 1cm. You definitely don't want to take them in (not that you are likely to find anything which will do this), but you can comfortably go up to ET+45. I am not sure what the cut off is. I think +45 to +48 fill out the wheel well a little better that +55. Some people might go with a lower offset for a more stanced look, but just make sure that the wheels are not going to start rubbing the arches.
    If you change the width that will affect the stance as well. At 7.5" width you wheels will appear to move inwards by a 1/4", so you might allow 6mm less on the offset for that. Likewise, if you went for a 8.5 width you might not want to go too low. Really just find a set you like and are listed to fit and you'll be good.
    Weight has other variations. Lighter will spin up more quickly, but heavier might soak up the bumps a little better. Too light and you'll use more gas on the highway (less momentum from a reduced flywheel effect - how much I don't know), too heavy and you'll use more gas everywhere. Mine are 6.5lbs lighter than stock (each) and I "think" I notice that I need a touch more throttle at times to maintain speed, but in return the car feels lighter and more nimble. The car felt bumpy with both the light wheels and the stock ones, lol.
  10. #23
    May 2014
    Hampden Maine
    Question
    Thanks a lot!!! E.T. stands for ??
    Mike
  11. #24
    Dec 2007
    Canada
    ET is from the German "Einpresstiefe", meaning insertion depth or something similar. It's the offset figure.
  12. #25
    May 2014
    Hampden Maine
    Your thoughts re forged vs cast? Thank you v.m.
  13. #26
    Dec 2007
    Canada
    My thoughts are that a good wheel is a good wheel. Oz and Enkei make some cast wheels which are supposed to be as strong as forged wheels. I have never had a forged wheel nor have I ever had a cast wheel go wrong on me. Go with whatever makes you feel comfortable in my opinion
  14. #27
    Jan 2014
    I just installed a set of Enkei T6S wheels. Do not want the OEM black wheels (plan on selling them). Click image for larger version.
  15. #28
    May 2014
    Hampden Maine
    wat are u asking for the stock wheels. I need a set for winter tires.
