Gas smell inside cab.
Results 1 to 10 of 10
This is a discussion on Gas smell inside cab. within the New Member Hangout forums, part of the Community - Meet other Enthusiasts category; When I get into if pretty hard there seems to be a heavy Gas smell inside my 2004 WRX Custom ...
    Registered User Roljr's Avatar
    May 2014
    Va.
    When I get into if pretty hard there seems to be a heavy Gas smell inside my 2004 WRX Custom ?? Thats the only time it. Happens any ideas ?? Thanks in advance.
    Oct 2005
    Late Devonian
    What modifications?
    Aug 2012
    Tucson, AZ
    Look for exhaust leaks as well
    Sent from my SCH-I545 using Tapatalk
    Stinkeye member 520
    May 2014
    Va.
    Exhaust apexin1 cold air intake thats it
    Oct 2005
    Late Devonian
    Is that just a catback?
    Look for fuel leaks (could be under the manifold though)
    Put the stock air box back in unless you are tuned for that intake - it may be making you run rich (or lean which is far worse but doesn't smell like gas).
    May 2014
    Va.
    Ok thanks
    Registered User tirerob's Avatar
    Nov 2012
    bug-eyeing in the Bakken
    +1
    This was one of my first posts as well. Mine turned outto be the little rubber fuel lines under the intake. Quite a job to repair without taking the intake off but I got it done. No more smell after two years just about.
    when my friends come up, i hear, "you sold the camarrrroooh.....HOLY BLEEP A WRX!"
    Ya has that effect on me too.
    Rob
    Where did he go?? http://www.clubwrx.net/forums/builds...ll-thread.html
    Registered User kpeters's Avatar
    Feb 2012
    Chicago, IL
    If all else fails from everyone else's thoughts, there was a recall on 2002-2006 WRX's for the vacuum tubes that was causing gas fumes to go into the cabin. I've had two separate WRX's that I had the recall done on. I would check and see if it was complied with on your car.
    Oct 2005
    Late Devonian
    Quote Originally Posted by kpeters View Post
    Yeah, when I clicked in here I was shocked that it wasn't a bugeye in the cold. We have a sticky on that and I have had it done myself.
    OP - you might want to google that for pics to see where it was happening - might be similar although your year isn't known for it. IIRC it was a fuel line that was contracting in the cold.
    May 2014
    Va.
    Thanks again for the info gonna try ANC see if that recall has been done buoght the car about 8 months ago so may be hard to fine out
