Fabricated exhaust - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 18 of 18
This is a discussion on Fabricated exhaust within the New Member Hangout forums, part of the Community - Meet other Enthusiasts category; Thank you this really helps. So the exhaust doesn't go over the rear axle, okay. Does the muffler scrape after ...
    Registered User PhillySS's Avatar
    Apr 2014
    Michigan
    Thank you this really helps. So the exhaust doesn't go over the rear axle, okay. Does the muffler scrape after you lowered it?
    Sent from my C6606 using Tapatalk
    Registered User 100plus2Vegas's Avatar
    Mar 2014
    Oceanside,Ca
    Your welcome. It goes under the axle to the side of the diff. I have scraped a few times since lowering. I just did a gradual bend after the diff so the muffler sits up at an angle and to the passenger side. Was fine before I lowered it. I just need to cut the piping after the diff, to rotate the bend up and add a bend to get the entire muffler up higher.
    Been meaning to do it, but been real busy at the shop I work at.
    It only scrapes on steep driveways.
    14 sedan: Protune: 318AWHP 344ft lbs up pipe, Tial EWG, AEM intake, Cobb AP V3, 3" TBE, Avo FMIC, Turbo Smart bpv, Aem air fuel gauge,Cobb knob,Perrin Pitch Stop mount, SPT front strut tower brace, K-Sport coilovers@1.5" drop. Eibach sways, Perrin Spherical end links, Cusco subframe brace, White Line sway braces, Perrin sub frame bushings.
    07 Duramax LBZ- 26psi,intake, TBE, Diablosport programmer, Edge Insight with EGT, EGR block off, BD exhaust manifold, PPE fuel valve.
    Apr 2014
    Michigan
    Okay gotcha, thanks for the insight! 😄
