Newbie Tranny questions
Results 1 to 10 of 10
This is a discussion on Newbie Tranny questions within the New Member Hangout forums, part of the Community - Meet other Enthusiasts category; I have an 02 WRX with plans pretty well laid out and plenty of research done. The engine is about ...
    Apr 2014
    I have an 02 WRX with plans pretty well laid out and plenty of research done. The engine is about to be built, I'm going bigger turbo, clutch upgrade, the whole 9 yards. I would like to know what my options are as far as a transmission/gear upgrade. Correct me if I am wrong, but if I am upgrading everything else, I am going to want to upgrade the tranny as well since it will be the weak link with all this extra power and being grabbed by a stronger clutch.
    If I am correct that the tranny should be swapped/upgraded what options do I have? I know the STi is very common but I was wondering if there are any 5 speed options available. The reason I am curious about 5 speed is 1) this is my first manual car and I am under the impression that a 6 speed takes constant attention, more so than a 5 speed and 2) correct me if I am wrong, but in a 5 speed you shift less often resulting in building speed quicker and holding boost longer, because I am under the impression that you have to rebuild boost when you shift.
    Any answers or suggestions on 5 speed vs 6 speed and my tranny options would be appreciated! Thanks
    Palmyra, NJ
    at the thread title.
    /immature
    Apr 2014
    Also would having a stronger tranny and clutch make it okay to launch the car? How does launch control work? Please explain!
    Apr 2014
    Oh that kind of tranny.
    Aug 2012
    Tucson, AZ
    In for posts
    Sent from my SCH-I545 using Tapatalk
    Hawkeye Alliance 520
    Previous cars:
    2010 Mitsubishi Lancer (sold)
    2009 WRX (sold )
    2013 Scion tC (sold)
    2008 Audi A4 (Totaled)
    Photographer/storm chaser
    https://www.facebook.com/kevinrimphoto
    IG - kevinrimcoski
    Palmyra, NJ
    Most of the OEM 5speeds from Subaru aren't the strongest. They can handle a fair amount of power as long as you aren't launching or slamming gears around, etc. Think 330-350 whp/wtq as an absolute high point (some people are fine with more power).
    There are aftermarket gear options that can be transplanted into 5spds however...PPG gearsets: helical or straight cut. These are notably much stronger and are built to handle much more power. They replace the stock gears within the tranny casing.
    The stock 6spd however is just a damn good transmission. It can handled a ton of power without any modification to gears. I don't know where you're getting "constant attention" from...but its just like any other transmission where you have to shift and downshift. No big deal. Now the gears on the 6spds are generally shorter, so you don't build boost as long, but its all relative. Shifting at the right points will keep you within the boost/power curve. A good thought however is that the 6spd is more geared to handled a track as opposed to a better daily driveable 5spd which has taller gears.
    If it were up to me...I'd take the 6spd. Its just a much better transmission. Much better feel. Just more fun to drive.
    These opinions and knowledge come from having had two STIs and now a WRX.
    zax
    zax is offline
    Super Modulator zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    Damn came here for pics...
    Here's an idea: don't beat on the car.
    Zax's Shaggin' Wagon (SOLD)
    Facebook me here
    Palmyra, NJ
    Butracekor!
            MainFrame's Avatar
    Austin, TX
    PPG 5mt gears (either helical or straight cut).. you will probably want to upgrade the rear diff to a r180 as well. Then you could launch it, but you would still be in danger of breaking things, like the front ring and pinion gear, shift forks.. axles.
    zax
    zax is offline
    Nov 2008
    If your gonna spend the money on PPGs, then straight cut. Becozracekor
    Facebook me here
