Newish to Subaru, just bought an 05 wrx, need turbo help - Page 5
Page 5 of 6 FirstFirst 123456 LastLast
Results 61 to 75 of 77
This is a discussion on Newish to Subaru, just bought an 05 wrx, need turbo help within the New Member Hangout forums, part of the Community - Meet other Enthusiasts category; Originally Posted by wreckingball man I notice no difference in smell or potency unless I put my face down to ...
  1. #61
    Registered User Gen Jack Oneil's Avatar
    Apr 2014
    Belgrade, MT
    Quote Originally Posted by wreckingball man View Post
    I notice no difference in smell or potency unless I put my face down to the tailpipe.
    what about in the cabin? if i got the dp with out the cat, does the smell come through the vents? ive read that if i get a catless dp, i have to do a tune at the same time, is that true?
    if the smell only comes through when i have the windows down, i can handle that. plus thats 200 less that i have to spend.
    I feel the need葉he need for speed!
  3. #62
    Jul 2012
    Rocky Top
    No difference in the cabin, windows down or up, no difference outside. It may smell different than normal exhaust, a slight gasoline smell; but no more proliferated or potent than the stock exhaust. Just my experience.
    You will have to tune for any downpipe you get when you install it, regardless of catted or catless.
  4. #63
    Apr 2014
    Belgrade, MT
    if i install the dp, and dont tune, atleast for a little while, will that cause any damage?
  6. #64
    MainFrame's Avatar
    Austin, TX
    Quote Originally Posted by Gen Jack Oneil View Post
    Not if you don't drive the car, or boost at all.
  7. #65
    Apr 2014
    Belgrade, MT
    well since its my everyday driver, not driving it is not an option, i could try and boost least as possible.
    i just did a dyno tune search for my area and there are only 2 places within 250 miles. im hoping the one that is 30 min away is good place, otherwise i got to go to the one that is in billings and that means a day drive there.
  8. #66
    MainFrame's Avatar
    Austin, TX
    You could e-tune.. it's not a complicated setup.
    You can hook the wastegate vacuum line directly to the compressor outlet to run spring pressure only (~5psi). That could make your car safe to drive if you go easy on it, but what's the point in installing the downpipe before you're ready to tune it? You'd be crippling the car.
  9. #67
    Oct 2011
    Santa Ana, CA
  10. #68
    Apr 2014
    Belgrade, MT
    i just called both places here that dyno tune, both can only do front wheel drive cars, no all wheel. the nearest place that can do a 4 wheel dyno tune is in spokane. a 5+ hour drive.
    S***
    i could hold off on installing the DP till i can go out there and install it and dyno tune it at the same time.
  11. #69
    MainFrame's Avatar
    Austin, TX
    S***
    You should only be talking to shops that specialize in Subarus.. I seriously doubt any Subaru performance shop only has a 2wd dyno.
  12. #70
    Apr 2014
    Belgrade, MT
    thats the thing, we dont have any Subaru shops around here, most of the performance shops here are for big / monster trucks.
    and the couple shops that specialize in subarus only do maintenance, nothing more
  13. #71
    MainFrame's Avatar
    Austin, TX
    Then I would either e-tune, or take a road trip to Surgeline, PDX, or one of the other PNW Subaru shops..
  14. #72
    Apr 2014
    Belgrade, MT
    well since almost everything i need to do requires a tune after, im thinking that i might just do this.
    i buy Frames turbo, have that + the uppipe installed.
    then next march, i buy: down pipe, Turbo Inlet Hose Pipe, intercooler hoses, Turbo vac, STI intercooler, bigger turbo + all parts need
    install them into the car. . . then haul the car to Surgeline and have the dyno test + tune done. and then drive the car back.
    or should i wait to do the uppipe with everything else?
    opinions?
  15. #73
    STinfection WRX-maniac's Avatar
    Sep 2013
    Western Maryland
    If you are replacing your turbo with another stock td04, then replace your uppipe while you are at it. You will not need a tune for the uppipe, plus it will be easy to get to with the turbo removed. The uppipe is not a performance mod, more of a preventative maintenance mod. Worth doing while you are there.
    Stink-Eye Mob #301
    2012 WRB STi Limited Sedan
    2011 WRB WRX hatchback---Retired and traded.
    http://www.clubwrx.net/forums/builds...sti-build.html <---- My STi build thread
    http://www.clubwrx.net/forums/builds...ld-thread.html <----My WRX build thread
  16. #74
    MainFrame's Avatar
    Austin, TX
    It's definitely cheaper and easier to do it all at once.. Although with the turbo out I would definitely replace the uppipe. Besides, you don't need to tune for that.
  17. #75
    Apr 2014
    Belgrade, MT
    alright, i know i havent posted in a while but im back and i have a complete ( or so i hope ) parts list. im hoping to get your opinions on my list. if there are any better options other than what i listed, let me know.
    since this is a sort of a different subject, i think i might make a new thread.
