Upgrade opinions
Page 1 of 3 123 LastLast
Results 1 to 15 of 32
This is a discussion on Upgrade opinions within the New Member Hangout forums, part of the Community - Meet other Enthusiasts category; Just bought an 02 WRX, it's my first Subaru and turbo vehicle. I have done some research and I am ...
    Apr 2014
    Upgrade opinions
    Just bought an 02 WRX, it's my first Subaru and turbo vehicle. I have done some research and I am trying to decide what upgrades will meet my goals. My friend owns a Cobalt SS turbo with 20lbs of boost and around 300hp. I'd like my car to closely match his in numbers. What would be a better route to go- COBB stage 2 kit, or a "can tune" with intercooler intake and exhaust upgrades followed by a protune? Keep in mind I want to (safely!) maximize boost without overdoing it and try to closely match my friend's Cobalt numbers. Open to any positive suggestions, Thanks!
    Registered User jtk07's Avatar
    Aug 2013
    North Dallas
    Definitely like the flexibility the accessport and protune offer.
    Cobb makes good stuff but there are many other great manufactures!
    ~Tyler K~
    Sent from my iPhone using Tapatalk please disregard typos!
    Apr 2014
    Quote Originally Posted by jtk07 View Post
    ~Tyler K~
    This might be a dumb question, but what exactly is an accessport? How does it differ from what COBB offers? Is an accessport the same thing as a "can tune" or "flash tune"? What supporting mods would be needed? And what exactly could I expect to see for numbers with just an accessport and protune? Thanks again!
    Apr 2014
    ~Tyler K~
    ¯\_(ツ)_/¯ Rambo's Avatar
    Oct 2010
    Portland, OR
    2007 Outback 3.0R wagon
    Jan 2012
    Philly Area
    Time for some reading!
    Start with the link in my sig, then:
    Cobb AP vs OpenECU (Tactrix/Romraider/ECUFlash)
    Then check out Cobb's website as Isaac posted. Specifically:
    https://static.cobbtuning.com/cobbtu..._WRX_02-05.pdf
    - Will
    Palmyra, NJ
    Can tune? Flash tune?
    All tunes are flashes of a new map to the ECU, optimized to run for the parts you add. Accessport is Cobb's way to flash a map onto the ECU.
    Dec 2011
    Pottstown PA
    to make around 300whp on a bugye youll want a different turbo, install injectors, fuel pump, turboback, uppipe, bigger tmic, can also go EWG. even at the same power levels he will most likely have you at higher speeds but you can get a better launch.
    Marky Mark
    My bugeye build
    MinoskePhotography
    Apr 2014
    Quote Originally Posted by Ruh Roh View Post
    How much money should I plan on putting into all of these upgrades? This may be a dumb question as well, but since I have AWD does that mean I could possibly make slightly less than the Cobalt's numbers and be pretty evenly matched? Or will the AWD mostly just effect the launch?
    Palmyra, NJ
    Quote Originally Posted by Stage02WRX View Post
    Why are you so dead set on beating a Cobalt? Shouldn't even be a worry of yours. Just enjoy your car for what you have and what you like out of it. There will always be a faster car out there than yours.
    You're looking at about $2k+ including a GOOD tune.
    You'll have the better launch...but if he has more power, he'll probably surpass you in the long run.
    Registered User lytlec's Avatar
    Jan 2009
    Central PA
    Just get snow tires and wait until the roads are covered and then you win.
    <-------- Taylor Swift.
    Hawk-Eye Alliance #137
    First Mods...what to do.
    Subaru Guide
    Apr 2014
    Thank you for clearing that up! I see this Accessport can be purchased as part of a stage 2 upgrade kit. How does a flash work? Do I plug it in somewhere on my car? Can it be done at home/on the go, or does it need to be done by a professional in a shop somewhere? Are all flash tunes purchased online the same way you would with the COBB Accessport? And why do you flash tune your car only to turn around and get it protuned immediately after? Wouldn't it make more sense to just do it all at once? Again, I'm new to all this so please keep up the positive information!
    Apr 2014
    It's not that I'm worried about beating the Cobalt, I jus like his set up and where his car's numbers are at, and I would enjoy it if my car was putting out similar boost, etc. Thanks for the answers on the cost of upgrades!
    Jan 2009
    Central PA
    A Protune is a custom tune made for your car and your current mods. It is the best way to get your car tuned. The cobb ap can be used to do this by a pro tuner. The cobb ap also comes with pre loaded maps based off your year wrx and certain mods which you need to follow the map notes exactly how they are or you will blow your car up.
    Subaru Guide
    STinfection WRX-maniac's Avatar
    Sep 2013
    Western Maryland
    Basically the way the cobb accessport works is it plugs into your OBD connector underneath your steering wheel, you plug it in, turn your car to "on" (not running), the accessport will mate to your vehicle, then upload the stock map to it for safe keeping. On your car, since its an 02, you will need to connect the green connector located to the left of your steering column under your dash in order to reflash the ecu. Once all that is done you select your desired map for your mods. For example "stage 2 93 octane" and wait for it to reflash your ecu. Unplug your green connector. Done.
    Stink-Eye Mob #301
    2012 WRB STi Limited Sedan
    2011 WRB WRX hatchback---Retired and traded.
    http://www.clubwrx.net/forums/builds...sti-build.html <---- My STi build thread
    http://www.clubwrx.net/forums/builds...ld-thread.html <----My WRX build thread
