New To Subaru And Learning How To Fix Cars (Especially Mine) - Page 9
Page 9 of 24 FirstFirst 12345678910111213141516171819 ... LastLast
Results 121 to 135 of 358
This is a discussion on New To Subaru And Learning How To Fix Cars (Especially Mine) within the New Member Hangout forums, part of the Community - Meet other Enthusiasts category; Thanks blank Sent from my HTC One using Tapatalk...
  1. #121
    Registered User Im_Aquaman's Avatar
    Mar 2014
    Phoenix
    Thanks blank
  3. #122
    Mar 2014
    Phoenix
    http://m.ebay.com/itm?itemId=350800789800 bad link I guess try this one
  4. #123
    Mar 2014
    Phoenix
    Update, I ordered a stock speedometer and am selling the meth kit to a friend
  6. #124
    Oct 2005
    Late Devonian
    Just FYI, you really shouldn't be driving that anywhere without an intercooler.
  7. #125
    Mar 2014
    Phoenix
    I'm not driving it and it has an intercooler it's just not mounted lol
  8. #126
    Dec 2011
    Pottstown PA
    what do u mean "not mounted"...
    Y pipe not connected or the two bolts near the downpipe and one near the windshield washer res. area not bolted down... Throttle body hose connected? this is a simple task to do. if you have a socket set and know righty tighty lefty loosey you can easily mount this and stop at the hardware store and buy the proper bolts/hose clamps.
    Marky Mark
    My bugeye build
    MinoskePhotography
  9. #127
    Mar 2014
    Phoenix
    Yeah it's all connected it's just not mounted down. I have to get the mounts and bolts and it'll be good to go. It's kinda just sitting there. I have no idea why, but then again the previous owners seemed like they were idiots anyway so I stopped asking these questions
  10. #128
    Mar 2014
    Phoenix
ID:	142689Click image for larger version.
  11. #129
    Oct 2005
    Late Devonian
    You should get a stock bypass valve and get rid of that blow off valve.
    What is the intake area looking like?
    So as the intercooler is in, we need to know the CEL codes it is throwing. If you were to get an opensource cable you could read those and flash an appropriate map and possibly get it running correctly. Otherwise it will indicate what hardware needs to be replaced. The ECU is limiting it to 3K RPM because it sees a major issue and is staying in limp home mode.
  12. #130
    Jul 2012
    Rocky Top
    Quote Originally Posted by Im_Aquaman View Post
    ...the previous owners seemed like they were idiots anyway so I stopped asking these questions
    This made me laugh
  13. #131
    Mar 2014
    Phoenix
ID:	142705 all I have atm I'm heading out of town right now
  14. #132
    Oct 2005
    Late Devonian
    I'm not familiar with that intake. Personally I'd find a cheap used stock setup and put it back. If you had the stock airbox etc. you could use an off the shelf map (opensource can be found free) for your tune probably. With that you will need a good etune at minimum.
    Is the exhaust stock (or can you take a pic closer on the turbo showing the downpipe?
    You need this badly (add the 02 wrx flashblock):
    EvoScan OpenPort 1.3 Interface for Mitsubishi and Subaru, EvoScan : Flash Tuner
  15. #133
    Mar 2014
    Phoenix
    The exhaust isnt stock it has a 3.5 inch straightpipe no muffler or catylitic converter lol
    First I'm going to fix the dangerous things first making it safe to drive, then I'm going to continue replacing everything making it as stock as possible. One piece at a time lol
    There's a shop nearby that can professionally tune it for me
  16. #134
    MTM
    MTM is offline
    Registered User MTM's Avatar
    Feb 2014
    NorCal
    NOT plug and play at all, that is why they are cheap. They have to take them out young there for env. regs.
    I came across you saying this and am confused. The EJ207 V7 specifically is very close to plug n play. Ill be doing this swap myself soon. And define "cheap" 3500-6500 depending on if you get the whole motor isnt that cheap imo. lol
    source for swapping
    EJ207 Info - NASIOC
    with an 02 there wouldnt be much to change.
    because my suggestion would be EJ207 and be done with it. The whole kit. Everything. Full JDM STi Drive train. Then you can keep your STi badges. It would be an STi.
  17. #135
    zax
    zax is offline
    Super Modulator zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    No, it's not at all easy. You will need the JDM harness and JDM ECU. In fact, it is the most difficult of all swaps. I thought I already explained this to you? Also, $3600 my ass.
    Zax's Shaggin' Wagon (SOLD)
    Facebook me here
