whiteline sway bars 13 wrx
Results 1 to 15 of 17
This is a discussion on whiteline sway bars 13 wrx within the New Member Hangout forums, part of the Community - Meet other Enthusiasts category; Hey I just purchased a 2013 wrx limited hatch and absolutely love it but i notice a lot of body ...
    Registered User BobbyDubRX13's Avatar
    Jan 2014
    Washington
    Hey I just purchased a 2013 wrx limited hatch and absolutely love it but i notice a lot of body roll... I'm looking into the whiteline sway bar set i have heard good things about it and also the Kart boy end links I'm not sure what mm sizes i should get and if i should do a negative camber alignment afterwards or leave it normal please let me know your thoughts thanks!
    Dec 2013
    North Pole
    Quote Originally Posted by BobbyDubRX13 View Post
    The front stock sway is 22mm and the rear is 16mm stock. I would start with a 19-22mm rear and see how that feels. I am in the same boat and plan on doing the rear sway and alighnment.
    Jan 2014
    Washington
    Nice man I appreciate it! I think I'll go 25 mm front and 22 mm rear then are you gonna use stock end links or upgrade?
    Sent from my SM-N900V using Tapatalk
    MAINEiac 11blackSTi's Avatar
    Nov 2012
    Land of the Port. ME
    24mm up front and 22 mm in the back is common. Good choice on the kartboy endlinks and good job doing some digging around before you posted up. I would say that even at 22 mm, the whiteline swaybar would do better the stock swaybar, and it can come in adjustable. I would max out your front and rear negative camber. There is not much you can do in the back for camber as it is not adjustable, but up front you should be able to get somewhere around -1.5 camber. Make sure there is very little to no toe.
    You don't want to run stock endlinks with aftermarket swaybars.
    On a side note, you might consider selling your stock tires and upgrading to something better (I run Michelin Pilot Super Sports). The stock tires aren't that great. I saw a huge improvement in handling (cornering and breaking) when I upgraded my tires. Just wanted to mention that since you are discussing handling
    Registered User kprugbyplaya's Avatar
    Nov 2012
    Lansdale, PA
    Well the rear IS adjustable but it requires $$$$.
    As 11blackSTi said, run 24 up front(adjust to stiffest setting) and 22 in the rear. You don't want to run anything bigger than 22mm(As far as I know) on stock springs.
    Here is nice link that will tell you what you need to know about sways
    The OFFICIAL Swaybar & Endlink FAQ ! - NASIOC
    I suggest you go over it.
    ¯\_(ツ)_/¯
    Kunal - Ordered 2015 DGM WRX
    Photographer | Dancer | Tech Nerd | The Stink-Eye Mob #7
    First Mods: What and what not to do
    2011+ Big Mod Thread
    How to Buy a Used WRX or STI
    Complete USED WRX Buying Checklist
    Sep 2008
    I was in your same situation and started with an STI 19mm RSB and it made a nice subtle difference but I then got to really wondering what a Whiteline setup would feel like. I ended up with 24mm FSB and 22mm RSB both adjustable with the WL KLC 182 and couldn't be happier. The STI sways you can find for about $40-$50 on iWSTI etc. but the Whiteline are great. With the Whiteline setup I also noticed how bad the stock tires are!
    Registered User WRX Piloti's Avatar
    Mar 2013
    Be sure and order the Kartboy endlink spacers when you order your setup, you'll need them...I'm running the Kartboy spacers with my Perrin endlinks and Cobb FSB, body roll has been greatly reduced.
    Jan 2014
    Washington
    Hey so one more question after I install these should I definitely get an alignment or do I not need to?
    Nov 2012
    You definitely should.
    Jan 2014
    Washington
    What specs should I be as far as camber caster and toe angle?
    Nov 2012
    Zero toe. I'd max out the negative camber. Probably looking at -1.5ish up front and it is what it is for the back, because its not adjustable back there.
    Registered User A265's Avatar
    Mar 2009
    in a igloo
    Adding sway bars don't require a alignment.
    That being said a custom alignment is one of the best if not the best bang for your buck mod you can do for handling. I would recommend it to everyone who hasn't got one to get it done.
    Since you have a 3rd Gen the rear camber can't be adjusted. Caster is pretty much static unless if you get a ALK or other mods.
    That leave Toe and front camber.
    I run -1.4 degree's front camber and 0 toe at all 4 corners. The toe is important for tire wear, so for a DD 0 toe is best. Camber depends how agressive you want to go, I would go more than -1
    This thread is a great resource when it comes to alignments.
    Alignment basics
    Jan 2014
    Washington
    Awesome thanks guys so would 1.5 inch negative camber make me burn through tires alot faster or would I be alright with that setup
    Nov 2012
    Camber doesn't have as big an effect as toe. -1.5 would be fine.
    Jan 2014
    Washington
    Sweet as far as setting up the sways stiffness wise should I go as stiff as possible or just in the middle also how much will that effect the overall ride of the car?
