Please I need HELP!!!
Results 1 to 9 of 9
This is a discussion on Please I need HELP!!! within the New Member Hangout forums, part of the Community - Meet other Enthusiasts category; Hey everyone whoever is reading this post, I am new to all these forums so I would really be thankful ...
    Dec 2013
    Exclamation Please I need HELP!!!
    Hey everyone whoever is reading this post, I am new to all these forums so I would really be thankful for all your advice tips and help!
    I have a 2009 Subaru wrx STi with 34k miles. So recently I have been driving on the freeway, and out of nowhere I started getting knocking. I loked it up and some people say it called Rod Knocking. I proceeded to keep driving home but 5 minutes later my car shut off on me just like that. It still cranks but doesn't start . Yes I have oil in tack. Please help what I can do? Thank you
    Registered User Ampliified's Avatar
    May 2012
    Warren Twp, NJ
    Is your car showing a CEL if you have an access port you can see what the codes are right now? Are their any modifications to the car?
    2012 DGM WRX - Stage Two 93 - Stink Eye Mob #908
    The Epic Life of Emily the WRX
            MainFrame's Avatar
    Austin, TX
    What do you mean by "knock"? Like your ECU was registering knock events.. or are you saying your engine started making a banging noise? If you had rod knock, then you should have shut the engine off the second you heard a noise and trailered it to a shop.
    What is "oil in tack"?
    If you spun a rod bearing, then continued to drive, your engine is probably toast and non much salvageable. First thing I would do is drain the oil and look for any bearing material in the oil.. and cut open the filter and look in there too. If there's metal in your oil and filter, then I would say it's safe to assume the engine is trash.
    Assuming your car is all stock (you didn't mention any mods), then just take it in and have the dealership replace your engine under warranty.
    Dec 2013
    P0301, 1st cylinder spark plug. But I have no modifications, all stock. But I don't believe that code has anything to do with the Rod Nock.
    Dec 2013
    Yes I was driving and all of a sudden I started getting noises from the engine. I pulled over and popped the hood, it was knocking quietly, so I had about 2 more miles to my house. So thats where I shut it down. And yes the oil has been changed two weeks ago, so I don't think it has anything to do with it? And yes its all stock !
    Ok so is it under warranty? 60K or five years, right? Have it flat bedded to the dealer.
            MainFrame's Avatar
    Austin, TX
    There are lots of things it could be, since rod knock is likely and you should still have a warranty, I would just go ahead and take it in.
    I'm engaged to my WRX. kedonot1's Avatar
    Oct 2013
    Syracuse, NY
    Hello, I currently go to school in a automotive class..The couple things I've seen are..
    1. Compression. Get a compression test and make sure no valves are stuck or bent..
    2. Injector. Make sure the injector is firing...you can check this with a stethoscope.
    3. Vacuum Leaks. Look at all hoses making sure nothing blew off, or any other possible intake issues.
    4. Sometimes Bad coils, coil boots, sparkplugs, etc. Check the spark plugs for carbon, etc.
    5. Lastly...The o2 sensor. I wouldn't even bother testing these unless you have a professional do it, because it gets complicated real quick..with the reading fuel trims, etc.
    Need help diagnosing check engine codes? Just message me!
    Sep 2011
    Sounds like the classic ringland failure...
