Wrx 03 stage 2 ... Help
Results 1 to 10 of 10
This is a discussion on Wrx 03 stage 2 ... Help within the New Member Hangout forums, part of the Community - Meet other Enthusiasts category; Well , previously I posted that I was putting some parts I got from eBay in my bugeye, and I ...
    Nov 2013
    Fort Hood, Texas, United States
    Well , previously I posted that I was putting some parts I got from eBay in my bugeye, and I got a lot of feedback saying all my parts were worthless and so on. Well I listen to some of the members and I sold them. On top
    Of that I messed up my engine and I got an other ej205 with less than 50k miles on it also as Well I got the money back from my parts and I put the cat back exhaust from cobb + the cobb af air box + uppipe + and tune it. Now my clutch is giving up on me and I will like to know of I should get a stage 2 or 3 clutch kit for my subi? Please help?
    MAINEiac 11blackSTi's Avatar
    Nov 2012
    Land of the Port. ME
    Quote Originally Posted by najarcitox View Post
    unless you are planning on going alot further with your mods, a stock replacement clutch would be fine as long as you don't beat the crap out of it.
    May 2007
    orlando flawduh
    You should get an oem replacement. Most choose Exedy
    Stage 2 or 3 clutch is way overkill with the mods you have
    Also your title says stage 2. Are you running a stage 2 map with those mods? If so you shouldn't be
    desiree
    ¯\_(ツ)_/¯ Rambo's Avatar
    Oct 2010
    Portland, OR
    Also note that the flywheel is considered a wear item, and Subaru does not specify a tolerance to which the flywheel can be resurfaced (i.e. Subaru believes it should just be replaced). There are shops that will resurface it for you, but the OEM Exedy clutch and flywheel combo are so cheap, it's best to just do it right as Subaru intended. Parts costs should be around $4-500. I was fortunate enough to have the dealer replace mine at cost (my dealer is awesome), so it was $600 out the door for all Subaru OEM parts and labor.
    You want an OEM clutch because for one thing, a stock clutch can easily handle Stage II power levels, and secondly, replacing a worn clutch is far cheaper than replacing a broken transmission, so I'd rather the clutch was the weakest link in the drivetrain.
    2007 Outback 3.0R wagon
    Nov 2013
    Yes I am running a stage 2 map on the car. I was told by the mechanic that a stage 3 will be good but the price with everything will be 580.
    Nov 2012
    We aren't talking about the map. We are talking about the clutch. You don't need a stage 2 or 3 clutch.
    Registered User Fender137's Avatar
    Jun 2013
    You're mechanic does not know what he's talking about. Stick with the oem Clutch and you'll be fine with the stage your currently at.
    Jul 2012
    Rocky Top
    He was responding to wrxtreme.
    Nov 2012
    Quote Originally Posted by wreckingball man View Post
    Ah yes you are right. I didn't realize we had already switched topics.
    May 2007
    orlando flawduh
    the mods you listed in your OP (catback, intake, uppipe) require a stage 1 map. the only time you should run stage 2 is if you have an aftermarket downpipe (unless you do have one and you just didnt mention it)
    desiree
