help ? 03 wrx engine
Results 1 to 9 of 9
This is a discussion on help ? 03 wrx engine within the New Member Hangout forums, part of the Community - Meet other Enthusiasts category; well, last time i was here, i posted i did some upgrades to my car and half of the comments ...
    Nov 2013
    Fort Hood, Texas, United States
    well, last time i was here, i posted i did some upgrades to my car and half of the comments were that i did everything wrong and that i was wasting my money. Well now i have a problem. my engine is fu*k , i believe i have a bad rod and idk if i should try to repair it or just buy a new engine. im open to any suggestions.
            MainFrame's Avatar
    Austin, TX
    That depends on your budget, and what you want to do with the car..
    Nov 2013
    i was waiting on the parts for stage 2 that are coming on the mail. right now my budget is 1670
  5. #4
    Nov 2013
    here is the video of my engine wrx 03 engine knocking sound - YouTube
  6. #5
            MainFrame's Avatar
    Austin, TX
    Quote Originally Posted by najarcitox View Post
    Unless you're doing the work yourself, you are going to have to increase your budget just to get it running again. Removing and replacing the engine can cost over $1000 in labor alone.
  7. #6
    Nov 2013
    i can do the swap but i dont feel confident enough to do the replacement of the rods
  8. #7
    Jan 2012
    New Jersey
    I watched this video a while ago to learn more about putting together an short block. It looks very time consuming (for a novice) and a lot of meticulous work but looks like something I would like to do. Maybe it can help. Though if you feel comfortable taking out the engine maybe you can bring the short block to someone to to that work for you. Subaru STI Short Block Assembly - YouTube
    CFLip2x 2012 WRB WRX Build
  9. #8
            MainFrame's Avatar
    Austin, TX
    First thing to do is make sure what the problem is. If the sound is coming from the bottom end I would drain the oil. If it has bearing material in it then pull the engine. If everything in the heads looks good you may be able to reuse them, but they will need to be cleaned throughly. If it were me and the problem is definitely a spun rod bearing, I would have a reputable shop completely rebuild the heads. Then either pick up a new OEM ej257 short block from Subaru and modify your combustion chambers, or reuse your ej205 case halves with an ej25 crank and rods, and some forged pistons for a 2.1L stroker. A lot of things should be flat out replaced, like the oil cooler, oil pump, tensoner.. should probably replace all the pulleys and water pump while you're at it.
  10. #9
    Nov 2013
    thank you for your suggestions , i think im gonna take it to a shop and see what they say and how much would it be, hopefully is under $3000
