Question about break in oil and transmission fluid changes
Results 1 to 6 of 6
This is a discussion on Question about break in oil and transmission fluid changes within the New Member Hangout forums, part of the Community - Meet other Enthusiasts category; When is a good time for the first oil change and transmission fluid change? Would you guys do the oil ...
    Registered User S20002STI's Avatar
    Garden City, KS
    When is a good time for the first oil change and transmission fluid change? Would you guys do the oil change at 1000 miles? I remember on the Evo forums people talked about getting the transmission fluid changed earlier because the synchros were getting broken in and they would find shavings. Could also be from the SST transmission because that is what they really suggested the early change on.
    Not sure if an earlier trans fluid change is reccommended on these as well. Any input is appreciated!
    Registered User JimboWRX's Avatar
    May 2013
    NY
    You have two options:
    1. Follow the owners manual with the following caveat: As far as going 7.5K miles between oil changes, I would advise against that. The wording in the manual is suggestive that that's the longest you could go...this is assuming that you still have oil left by then (remember your turbo will consume some oil). The advice I got from a Subaru Parts Manager (who happens to be a WRX STI enthusiast and owns his own garage) suggested a 3.75K mile oil change interval. That's what I'm following.
    2. You could simply do the first oil change at 3.75K miles or sooner and have Blackstone do a UOA. They'll tell you what interval you should follow based on the UOA results. They'll even tell you if you should change oil brands.
    Tranny fluid isn't getting changed until the interval required by the owners manual.
    Doing fluid changes more often than necessary is just a waste of money.
    Sep 2011
    3,750 seems like overkill with full synthetic IMO.
    Garden City, KS
    Thanks for the responses. I don't think i would really feel comfortable waiting until 7000+ miles to do an oil change. I think the 3000-4000 range makes me feel better. I won't put many miles on it anyway just trying to prepare for when it gets here.
    Jan 2012
    New Jersey
    I changed the tranny fluid on mine at 30K very simple just need to get the correct Torqux bit. I get my oil changed around the 5500+ miles synthetic shouldn't need to be changed that early but im not 100% on that.
    DIY: Transmission Fluid Change
    CFLip2x 2012 WRB WRX Build
    Garden City, KS
    Thanks for the link and input!
