Hi all I'm new to site and need some advice bugeye lost power no boost
Results 1 to 15 of 26
This is a discussion on Hi all I'm new to site and need some advice bugeye lost power no boost within the New Member Hangout forums, part of the Community - Meet other Enthusiasts category; Sorry i posted this here but new and not sur we're to post I have a 2001 bugeye wax turbo ...
    Aug 2013
    I was driving along as norm and went to toe it to find that there was no boost and was driving like a 1.1 corsa lol
    Car runs and tics over like it should no smoke at all
    What I have done so far
    Oil cap check
    New up pipe
    Replaced y pipe under intercooler
    Reset ecu
    Took batt off for an hour
    Still the same
    Can some one help please
    MAINEiac 11blackSTi's Avatar
    Nov 2012
    Land of the Port. ME
    Check all of your connection points around your intercooler (below as well) to make sure they are tight.
    Aug 2013
    Hi have done this as I had a blue pro drive y pipe on it and have now put a standard hard y pipe on as i Thought it was that as the pro drive one was suckin flat thanks
  5. #4
    Jan 2012
    Philly Area
    Any CELs?
    - Will
  6. #5
    Aug 2013
    Hi no cels I have an psi ecu monitor in the car it if showing 0 fault codes have reset the ecu
  7. #6
    If you genuinely have zero boost check the C clip on the wastegate actuator, it may have fallen off.
    - Al Stewart
  8. #7
    Aug 2013
    Will check that now and post up date thanks
  9. #8
    Jul 2012
    Rocky Top
    There was a guy on here not too long ago that had the same problem, zero boost, although he also had no turbo spool. He said his turbo had completely seized up lol.
    *It's a complete longshot no doubt, just posted for entertainment and novelty factor more so than anything.
  10. #9
    Aug 2013
    Right have checked wastegate clip that's ok have also just changed actuator but still the same I could change the turbo but seem bit strange ????????????
  11. #10
    The turbos rarely fail. Consider pressurizing the intake and checking for leaks. Cheaper, and I like to start cheap.
    By the way, are you sure the exhaust aft of the turbo is not obstructed?
    - Al Stewart
  12. #11
    Aug 2013
    Not sur about the down pipe how likley is it to be that
  13. #12
    I've heard of it once and I've been here eleven years. It is possible.
    When you replaced the up pipe did you give the turbo a quick look? Is your dump valve the works recirculating unit, and is it both connected and working (begging the question, how would one know if it's working without boost, yes I know).
    - Al Stewart
  14. #13
    Aug 2013
    Hi no the dump valve is not working it is sliding up and down but not enough to make a noise
  15. #14
    Palmyra, NJ
    Pull the intake inlet off and see if the propeller on the turbo is seized. That's an easy check. You could also do this by pulling off the downpipe. Either side really.
  16. #15
    So could the dump valve be leaking?
    If you do remove the down pipe to check the turbo (on a stone cold car, don't ask why I say so...) check for no obstructions in the pipe too.
    - Al Stewart
