Hi all I'm new to site and need some advice bugeye lost power no boost - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 26 of 26
This is a discussion on Hi all I'm new to site and need some advice bugeye lost power no boost within the New Member Hangout forums, part of the Community - Meet other Enthusiasts category; Had the cat go bad on a Merc wayyy back, didn't run worth sh!t with the chunks blocking the exhaust. ...
    Registered User Ingo's Avatar
    Mar 2012
    Colorado Springs, CO
    Had the cat go bad on a Merc wayyy back, didn't run worth sh!t with the chunks blocking the exhaust. COULD be...
    Aug 2013
    I have tried a different dump valve on it but the other one don't move at all it boost up to about 0.6 then it's like a flat spot
    But the car will still rev to red line
    So wait, you can get over half a bar of boost? So you're at wastegate pressure, not zero. Ok check boost leaks, wastegate actuator, boost solenoid, and exhaust as above.
    Les jeux sont faits.
  5. #19
    Aug 2013
    Will check them today have already changed the actuator to rule that out have put new y pipe and connectors on tried different dump valve replaced the up pipe for new one
    Thanks
  6. #20
    Jul 2012
    Rocky Top
    Your ebcs may not be functioning, or check all the vac lines running to it. Do you have the restrictor pill?
    See pic in link:
    Technical Articles
  7. #21
    Aug 2013
    Think I have found the issue like I said in an earlyer post I had changed the up pipe
    I have now removed the turbo and yes in deed it was jamed bits of the cat from the uppipe was in there have got them out and it spins nice again but as it has been jamed I'm going to put my spare turbo on so fingers crossed will be back on the road today yay can't wait lol
  8. #22
    Wow congrats. The stock turbo is rebuild able if it's a Mitsubishi TD0x series and not an IHI VFxx. You might keep it as a spare core.
  9. #23
    slow no mo' ! Shoopster's Avatar
    Apr 2013
    Montreal
    I was stuck in vacuum purgatory 'til we replaced the boost control solenoid. There's a test for that, but I couldn't explain it to you. I know someone who could, though...
    Edit: Oops I just read that you might have solved the problem. Fingers crossed.
    -Stephanie 2004 WRB WRX | Blobeye Syndicate Member #104
    "I can't see the Shoopster from here; I'll wait for you outside."
    Shoopsterbuild 2.0: Better than it was before. Better, stronger, faster. And such JDM, yo.
  10. #24
    Registered User tirerob's Avatar
    Nov 2012
    bug-eyeing in the Bakken
    holy crapp. pics of the bits. post carnage. so we can all see the best reason for up pipe lol.
    when my friends come up, i hear, "you sold the camarrrroooh.....HOLY BLEEP A WRX!"
    Ya has that effect on me too.
    Rob
    Where did he go?? http://www.clubwrx.net/forums/builds...ll-thread.html
  11. #25
    Jul 2012
    Rocky Top
    Did someone say pics of the carnage?
  12. #26
    Aug 2013
    Wright swopped the turbo the dump valve sounds louder than ever before just got air lock to sort any advice would be cool
    But when it revs now it sounds like it has a rev limiter when it hits red line did come up with error code p0250
    What says is wastegate solenoid but think it could be the induction pipe from the air box to the turbo it has gone soft were it connects ?????
