question on possible used wrx - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 23 of 23
This is a discussion on question on possible used wrx within the New Member Hangout forums, part of the Community - Meet other Enthusiasts category; Originally Posted by Miggs The price is a bit high. I would offer k. Other than that it looks pretty ...
    Palmyra, NJ
    Quote Originally Posted by Miggs View Post
    The price is a bit high. I would offer $6k. Other than that it looks pretty clean.
    Honestly, an $8k asking price is really good. Bugeyes under 100k on the clock are still pulling $9k-$10k all over the place. I'd offer $7k if it checks out...wait for his counter at $7500 and take the deal. You don't want to low ball the **** out of the guy.
    Aug 2013
    Alright guys, I got another question. So the owner brought the car in to the shop a few weeks ago and he sent me the inspection list. I will list some things here and let me know if these are normal problems or if the car has been beaten on more than it should?
    Also, the link to the car is in my last post. Its the 2002 wrx.
    inner axel boots split open and cracked on all four sides
    Rotors warped, breaks new.
    alignment issues
    Shift shaft seal leaking
    High pitched whine from front of engine; could be alternator further inspection required.
    No problem is normal.
    I don't drive around with split axle boots.
    Since further inspection is required for the whine, nobody can answer that.
  6. #19
    Aug 2013
    Quote Originally Posted by doinwork34 View Post
    alignment issues
    -The boot splitting could be from wear and tear, but you still need to get the axle off. Boot = $20 ish. If you're saying the axle is cracked, you're going to be replacing all four which I think run around $110 each (I'm using a number from my Si, for the subbie it could be higher)
    -The rotors are warped so no questions asked, those will need to be replaced. Depending on how much you want to spend, anywhere from $40 on up. (warped rotors is a good sign that the car was either driven recklessly or hard. There are occasions where they're just old from never being replaced. You'll have to find out when they were replaced and make an educated a guess on what happened)
    -alignment is normal. Could be from getting new rim/tires without a balance, hitting a curb, having the rim hit something, or just normal driving and tear. The list could go on but you get the idea.
    -Shift shaft leaks? Transmission issue. Easy fix though, just have to buy new gaskets. Again, not familiar with subbies but this is really not normal. Let's say, out of the ordinary.
    -Engine whining? Could be a bunch of different things.
    Long story short, just about everything on that list is something that is you don't deal with on a regular basis, i.e. not normal.
    ^ 100%
  7. #20
    Aug 2013
    thanks guys. I checked out the car and once I heard the whining I quickly recognized it as the water pump pully bearing, so that should be an easy fix when I replace the belts.
    I think the rotors are warped from just being old since the car is 11 years old...and Im sure it was driven hard at some point... (of course I will do a little more investigating as Skandiluz suggested)
    The 'boots' are torn and cracked. Not the actual axel or joint. But the car still rides, idles, and steers totally smooth so I would assume not too much damage has been done yet. Im thinking I may rebuild the joints and get new boots to prolong the axle life(will that help at all?).
    And the shift shaft leak seems to be very, very small since I cant seem to even find any leaked fluid around it. But the mechanic said it was there, so I will keep an eye on it.
    And the alignemnt issue is not a big deal since its like 80 bucks to get it fixed.
  8. #21
    Aug 2013
    Everything seems to check out. If it's the boot itself, they're like $10-$25 a piece, not a big deal, as long as the axles themselves are still in tact. I'd look at how much wear there is and decide if you want to replace them or not. Other than the shaft leak, I'd say get it if the price is right. The most you're looking at is $600 to get everything fixed/repaired, but this is on the high end, so I doubt you'll even pay that much. Just try to get as much detailed information as you can from the seller and a mechanic. Good luck with it.
  9. #22
    Palmyra, NJ
    Quote Originally Posted by Skandiluz View Post
    I've never heard of a case where you can just replace the boot. I was always under the impression that you had to replace the whole axle on a Subaru...
  10. #23
    Aug 2013
    That is probably true for Subaru's, I wouldn't know as I do not own one yet. I have however replaced the boot on my 92 civic, so I used that as my reference. After 2 months I ended up replacing the front axle anyway.
