2002 Subaru wrx short block build up questions!
Results 1 to 2 of 2
This is a discussion on 2002 Subaru wrx short block build up questions! within the New Member Hangout forums, part of the Community - Meet other Enthusiasts category; Hey guys im new to club wrx and i just had a few questions! If i sound like i dont ...
    Aug 2013
    Wyo
    If i sound like i dont know anything its because i dont and im trying to learn everything i can. Okay so my question is if i rebuild my shortblock in my subaru wrx, is it going to bolt up fine to the rest of my motor? Or would i have to get a fully new ej20?
    Thanks guys!
    Jul 2012
    Rocky Top
    When you rebuild your engine you should have the heads machined as well. Everything will bolt back on water/oil pump, belts, pulleys, heads. What exactly are you confused about? You will not need to buy a new motor.
    A rebuild is usually
    -pistons and rings
    -gaskets
    -bearings
    -water/oil pump
    -belts
    -pulleys
    -maybe rods, maybe crankshaft
    Also, the cylinders are machined out and they become slightly larger in diameter, meaning you need slightly oversized piston rings. Also, the heads are machined down so they fit perfectly on the shortblock again.
    Rebuilding the heads is another story...
