Turbo!!! I need help
Page 1 of 3 123 LastLast
Results 1 to 15 of 31
This is a discussion on Turbo!!! I need help within the New Member Hangout forums, part of the Community - Meet other Enthusiasts category; I have a wrx. I think something is wrong with my turbo it's not boosting and and something sounds deep ...
    Jul 2013
    TN
    I have a wrx. I think something is wrong with my turbo it's not boosting and and something sounds deep like a deep rumble. I put a new blow off valve on so not sure if that has anything to do with this or not. Any body got any info?
    Jan 2012
    New Jersey
    is the blow off vent to atmosphere? if so can you set it to recirculate if yes do that if no put the old one on (if it still works)
    and after that what year what mods
    CFLip2x 2012 WRB WRX Build
    Jul 2013
    TN
    It's a 09 impreza wrx. I am not to sure if it is or not. The one I got is a turbosmart plumb black. It says recirculating. I just hooked it right up and went. Didn't know if there was anything to do.
    Jul 2013
    TN
    Part # is TS-0203-1209
    Registered User ProZach626's Avatar
    Aug 2008
    Home of the blues, the Blues, and the real life blues.
    Sounds like you have a hole in your fuel map.
    Jul 2013
    TN
    Quote Originally Posted by ProZach626 View Post
    Isn't a fuel map just a sensor.
    Jul 2013
    TN
    Need some advice!
    So my wrx isn't boosting. I have no idea where to start. This is my first turbo car. It isn't making a wining noise that I can tell. Anyone can help would be greatly appreciated.
    Registered User SDub's Avatar
    Feb 2013
    Well what have you done to it? I'm sure you're getting boost. If it's stock, you will hear virtually nothing of the likes of turbo.
    No whoosh, no hiss, no whining.
    Sent from my SCH-I535 using Tapatalk 2
    Feb 2013
    The car wouldn't move if your turbo wasn't working, is all I'm saying.
    The only reason I can think of for absolutely zero boost -- this means the motor is operating at vacuum or at most atmospheric pressure -- is if the C-clip on the control arm were to have fallen off. If you were adjusting the WG arm at one point this is suspect.
    Otherwise, define precisely what "not boosting" means and list all modifications.
    Feb 2013
    This
    Jul 2013
    TN
    I have only put a new bov on it but I switched it back out for the stock and it didn't make a difference. When I hit the rpm range for the boost to kick in nothing happens just sounds like a engine running on high rpm's
    slow no mo' ! Shoopster's Avatar
    Apr 2013
    Montreal
    ...manual or automatic?
    -Stephanie 2004 WRB WRX | Blobeye Syndicate Member #104
    "I can't see the Shoopster from here; I'll wait for you outside."
    Shoopsterbuild 2.0: Better than it was before. Better, stronger, faster. And such JDM, yo.
    Feb 2013
    Quote Originally Posted by Shoopster View Post
    Stop....
    Sent from my Fone
    Jul 2013
    TN
    5speed manual
